So this is starting to get bad. I'm trying to help someone who doesn't know Lisp, and they keep adding items to the list of things they want the lisp to do. If it's simple I add, and I thought this one was. The lisp is the one posted in the show your stuff, where you select blocks you want to redefine by a master library drawings definition of said block. It will search to see if the block has any nested blocks, and if so, it will update those definitions also. At least it is supposed to, and the code says it does ( to show you can uncomment out the items in read in the code below ). The main problem that was brought to me was that nested block items Linetypes were not being copied. So I put in the commented part to see if they were or not, and they were, but the drawing does not reflect that. I have tried many things, and have not come up with a way that works. I am now wanting to figure it out for my own sanity.
Any help is appreciated. I can post two drawings if neccary, but to show what is wrong, create a rectangle change it to hidden. Make that rectangle a block, then make that block into another block. Save that drawing as 'c:\test\block.dwg'. Close that drawing. In a new drawing do the same thing except don't make the first rectangle hidden, but name all the blocks the same. The code will say that it updated it, but it will not reflect the hidden linetype.
Now for the code
(defun c:UpdateBlock (/ BlkDwgPath dbxApp oVer bDidError ActDoc BlkCol fromBlkCol cnt ss Ent EntData BlkName
BlkDef BlkNameObjList *error* GetBlockDefinitionObjects)
(defun *error* (msg)
(if fromBlkCol (vlax-release-object fromBlkCol))
(if dbxApp (vlax-release-object dbxApp))
(setq fromBlkCol nil)
(setq dbxApp nil)
(if msg (prompt (strcat "\n Error-> " msg)))
(defun GetBlockDefinitionObjects (BlkCol BlkName BlkNameObjList / ObjList tempName)
(if (not (vl-catch-all-error-p (setq BlkDef (vl-catch-all-apply 'vla-Item (list BlkCol BlkName)))))
(vlax-for obj BlkDef
(and
(= (vla-get-ObjectName obj) "AcDbBlockReference")
(not (assoc (setq tempName (vla-get-Name obj)) BlkNameObjList))
(setq BlkNameObjList (GetBlockDefinitionObjects BlkCol tempName BlkNameObjList))
(setq ObjList (cons obj ObjList))
(if ObjList
(setq BlkNameObjList (cons (cons BlkName ObjList) BlkNameObjList))
BlkNameObjList
(setq BlkDwgPath "c:/test/Block.dwg")
(setq dbxApp
(if (< (atoi (setq oVer (substr (getvar "acadver") 1 2))) 16)
(vla-GetInterfaceObject (vlax-get-acad-object) "ObjectDBX.AxDbDocument")
(vla-GetInterfaceObject (vlax-get-acad-object) (strcat "ObjectDBX.AxDbDocument." oVer))
(setq bDidError (vl-catch-all-error-p (vl-catch-all-apply 'vla-Open (list dbxApp BlkDwgPath))))
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq BlkCol (vla-get-Blocks ActDoc))
(setq fromBlkCol (vla-get-Blocks dbxApp))
(setq cnt -1)
(and
(not bDidError)
(setq ss (ssget '((0 . "INSERT"))))
(while (setq Ent (ssname ss (setq cnt (1+ cnt))))
(setq EntData (entget Ent))
(setq BlkName (cdr (assoc 2 EntData)))
(if (not (assoc BlkName BlkNameObjList))
(setq BlkNameObjList (GetBlockDefinitionObjects fromBlkCol BlkName BlkNameObjList))
(foreach lst (reverse BlkNameObjList)
(vla-Delete obj)
(vlax-invoke dbxApp 'CopyObjects (cdr lst) BlkDef)
(prompt (strcat "\n\n Updated block: " (car lst)))
[color=red];(vlax-for obj BlkDef
; (prompt (strcat "\n " (vla-get-ObjectName obj) " [ " (vla-get-Linetype obj) " ]"))
;)[/color]
(prompt "\n")
(vla-Regen ActDoc acActiveViewport)
(*error* nil)
Updated block: nested
AcDbPolyline [ HIDDEN ]
Updated block: main
AcDbBlockReference [ BYLAYER ]
