Author Topic: WHY "FIX" FUNCTION ERROR ?  (Read 2753 times)
hunterxyz
« on: May 18, 2008, 09:14:37 AM »
(SETQ AA 10)
(SETQ BB 0.538516)
(SETQ CC (*(COS 1.9513026954188)BB))
(SETQ DD (ABS (* CC AA)))
_$ 2.0
(SETQ EE (FIX DD))
_$ 1
Asks fellow masters to explain thanks ~
gile
  • Marseille, France
Re: WHY "FIX" FUNCTION ERROR ?
« Reply #1 on: May 18, 2008, 09:41:40 AM »
May be a difference between the 5 decimal rounded displayed value (2.0) and the 16 decimal rounded value used in calculus (1.999998172232795)
Try (rtos DD 2 16)
DEVITG
« Reply #2 on: May 18, 2008, 01:11:35 PM »
(SETQ AA 10)
(SETQ BB 0.538516)
_$ 2.0
(setq dd$ (rtos dd 2 15))
"1.999998172232795"
(setq dd# (atof dd$))
;;;_$ 2.0
(setq dd& (fix dd#))
;;;_$ 1
(SETQ EE (FIX DD))
;;;_$ 1
VovKa
  • Ukraine
« Reply #3 on: May 18, 2008, 01:38:53 PM »
_$ 1.99999
1.99999
_$ 1.999999
2.0
visual lisp console uses some kind of rtos to print out the results. don't trust what you see :)
hunterxyz
« Reply #4 on: May 18, 2008, 07:30:30 PM »
How to let SET EE = 2
« Reply #5 on: May 18, 2008, 08:58:50 PM »
(distof(rtos dd 2 0))
gile
  • Marseille, France
« Reply #6 on: May 19, 2008, 04:07:26 AM »
Instead of fix function, you can use a rounding function, there're many around here, you can see this thread.
Here's mine (last release)
(defun round (num prec)
  (if (zerop (setq prec (abs prec)))
    num
    (if (minusp num)
      (* prec (fix (- (/ num prec) 0.5)))
      (* prec (fix (+ (/ num prec) 0.5)))
Using:
(round pi 0.01) -> 3.14
(round pi 1e-5) -> 3.14159
(round 5456.50 1) -> 5457
(round 5456.50 100.0) -> 5500.0
Note that if prec argument is an interger, the result will be an integer too.
« Reply #7 on: May 19, 2008, 08:45:02 AM »
VovKa
  • Ukraine
« Reply #8 on: May 19, 2008, 01:31:41 PM »
another one using vb data types
;;;range (Signed) of vlax-vbLong is −2147483648 to 2147483647
;;;uses 'Round-to-even' method
(defun Int (InReal)
  (vlax-variant-value (vlax-make-variant InReal vlax-vbLong))
_$ (Int 3.5)
4
_$ (Int 4.5)
4
daron
« Reply #9 on: May 19, 2008, 02:20:30 PM »
Hey Vlad, if 3.5 rounds to 4, should 4.5 round to 5 and maybe 4.49 round to 4?
VovKa
  • Ukraine
« Reply #10 on: May 19, 2008, 05:15:39 PM »
Columbia
« Reply #11 on: May 20, 2008, 08:05:06 AM »
Wow...you learn something new everyday.  I just learnt mine.  Does that mean I get to go home now?
« Reply #12 on: May 20, 2008, 08:36:01 AM »
Great link VovKa  8-)
