Author Topic: Oh the joys of a "high level" language!  (Read 8158 times)
Chuck Gabriel
Re: Oh the joys of a "high level" language!
« Reply #15 on: May 16, 2008, 07:14:28 AM »
Chuck,
Similar short of thing :) happened in your 'C# HotKeys' thread if memory serves and the solution then was a cast to short as well.
Glad it worked for you and good to see you having a dabble again.
Cheers,
Glenn.
You have an excellent memory.  I wasn't going to bring that up, because it makes me feel like a complete schmuck that I missed the exact same thing again. Apparently I have some sort of subconscious prejudice against shorts.  :D
Chuck Gabriel
« Reply #16 on: May 19, 2008, 10:45:51 PM »
Here is the final code I ended up with if anybody is interested:
using System;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Windows;
using ofdFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags;
using sfdFlags = Autodesk.AutoCAD.Windows.SaveFileDialog.SaveFileDialogFlags;
namespace CGabriel
    public class LispFileDialogs
        public static string title;
        public static string defaultFileName;
        public static string defaultExtension;
        public static short flags;
        [LispFunction("GetOpenFileDialog")]
        public static ResultBuffer GetOpenFileDialog(ResultBuffer args)
            if (!parseArguments(args)) return null;
            ofdFlags dlgFlags = (ofdFlags)flags;
            if (((dlgFlags & ofdFlags.DefaultIsFolder) != 0) && Path.HasExtension(defaultFileName))
                defaultFileName = Path.GetDirectoryName(defaultFileName);
            OpenFileDialog dlg = new OpenFileDialog(title, defaultFileName, defaultExtension, title, dlgFlags);
            if (dlg.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return null;
            ResultBuffer result = new ResultBuffer();
            foreach (string file in dlg.GetFilenames())
                result.Add(new TypedValue((int)LispDataType.Text, file));
            return result;
        [LispFunction("GetSaveFileDialog")]
        public static TypedValue GetSaveFileDialog(ResultBuffer args)
                return new TypedValue((int)LispDataType.Nil, null);
            sfdFlags dlgFlags = (sfdFlags)flags;
            if (((dlgFlags & sfdFlags.DefaultIsFolder) != 0) && Path.HasExtension(defaultFileName))
            SaveFileDialog dlg = new SaveFileDialog(title, defaultFileName, defaultExtension, title, dlgFlags);
            return new TypedValue((int)LispDataType.Text, dlg.Filename);
        public static bool parseArguments(ResultBuffer args)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            if (args == null)
                return notEnoughArguments(ed);
            ResultBufferEnumerator iter = args.GetEnumerator();
            iter.MoveNext();
            if (iter.Current.TypeCode != (short)LispDataType.Text)
                return wrongArguments(ed);
            title = (string)iter.Current.Value;
            if (iter.MoveNext() == false)
            defaultFileName = (string)iter.Current.Value;
            defaultExtension = (string)iter.Current.Value;
            if (iter.Current.TypeCode != (short)LispDataType.Int16)
            flags = (short)iter.Current.Value;
            return true;
        public static bool notEnoughArguments(Editor ed)
            ed.WriteMessage("\nToo few arguments.");
            return false;
        public static bool wrongArguments(Editor ed)
            ed.WriteMessage("\nExpected string string string int.");
            return false;
There are a couple of reasons I did this.
1) I've had getfiled return bogus results.
2) It wanted the ability to select multiple files like dos_getfilem, but with the drawing preview in the file dialog like getfiled.
I hope somebody finds it useful.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: May 20, 2008, 02:57:06 AM »
Very nice Chuck!
Glenn R
« Reply #18 on: May 20, 2008, 03:05:03 AM »
Well done old chap!
Chuck Gabriel
« Reply #19 on: May 20, 2008, 07:38:27 AM »
Thanks guys.
« Reply #20 on: May 20, 2008, 07:48:04 AM »
Nice Chuck.
Looks like Lisp is going to get a helping hand as NET gets more use.
OT
Well done old chap!
very British !
Glenn R
« Reply #21 on: May 20, 2008, 07:50:23 AM »
Hehe...when in Rome Kerry... :)
Glenn R
« Reply #22 on: May 20, 2008, 07:52:16 AM »
Actually, I'll be in Italy tomorrow...
BillZndl
« Reply #23 on: September 27, 2011, 02:20:02 PM »
Thanks Gab!
This solves my problem of the Autolisp Getfiled function not working properly in 64 bit.
BillZndl
« Reply #24 on: July 26, 2012, 08:04:32 AM »
Thanks Gab!
I have found one problem with the OpenFileDialog Lisp Function.
When using inside my lisp programs, the OpenFileDialog will open to a directory other than the one that's input.
It appears to open to the previously selected directory instead of the designated input string.
example:
(setq dwgnm (GetOpenFileDialog "Hello" "G:\\2013\\Options\\"  "dwg" 2)
will open to: "G:\\2013\\Options\\Outfitter\\".
Even if I change the input string to just "G:\\" it will do the same thing.
The OpenSaveDialog does not exhibit the same behavior curiously enough.
MexicanCustard
« Reply #25 on: July 26, 2012, 12:37:13 PM »
The fourth parameter of OpenFileDialog is the name AutoCAD uses to store the screen location and last opened directory from within that dialog.  Every time you use that name you get the default location and folder that AutoCAD used last time when using that dialog.
BillZndl
« Reply #26 on: July 30, 2012, 10:45:05 AM »
Thanks for the reply.
So the dialog ignores the second argument completely?
Any work arounds on this one?
MexicanCustard
« Reply #27 on: July 30, 2012, 11:14:53 AM »
Not that I've tried.  I've assumed AutoCAD stores these values in the Registry. You might try looking there to see if you can overwrite or delete these values.
