Author Topic: Getting info from an XML file  (Read 3016 times)
psuchewinner
« on: May 14, 2008, 09:30:17 AM »
Can ayone tell how the retreive info from an XML document using Visual Lisp?
Like listing the "Children" from the "Parent"?
daron
Re: Getting info from an XML file
« Reply #1 on: May 14, 2008, 09:33:25 AM »
It doesn't appear that too many people have delved into XML with lisp and the two people I know that did, don't visit here much if at all anymore. If you go to Columbia's profile, you might be able to email him or at least send him a personal message.
psuchewinner
« Reply #2 on: May 14, 2008, 09:44:04 AM »
Thanks, I was thinking about that.
daron
« Reply #3 on: May 14, 2008, 10:13:04 AM »
Seems to have worked. Long time no see, Columbia.
Columbia
« Reply #4 on: May 14, 2008, 10:13:47 AM »
I'm still around, Daron, I just don't have the time to lurk and respond as I used to.  :(
Besides, it seems by the time I get to a topic, about 600,000 people have already answered the question that was asked.  I feel a little redundant saying the same thing somebody else has said.
« Reply #5 on: May 14, 2008, 10:31:29 AM »
Here is a little something to point you in the right direction ... it could be improved substancially but I think it will give you some ideas about how to proceed.
(defun mlchild(/ doc xmldoc xmlchildren)
(if (= xmlc-NODE_TEXT nil)
(vlax-import-type-library
  :tlb-filename "msxml2.dll"
  :methods-prefix "xmlm-"
  :properties-prefix "xmlp-"
  :constants-prefix "xmlc-")
(setq doc (getfiled "" "" "" 8))
  (setq xmldoc (vlax-create-object "Microsoft.XMLDOM"))
  (xmlm-Load xmldoc doc)
  (setq xmlchildren (vlax-get xmldoc 'childNodes))
  ;;; work on the child nodes here ... there may be nested child nodes!!
  ;;; don't forget to release your objects ;)
psuchewinner
« Reply #6 on: May 14, 2008, 10:38:52 AM »
Thanks for the help.
You know?, It weird, I usually catch on to this stuff pretty fast but this is new to me and I am struggling.
I will chew on this.
daron
« Reply #7 on: May 14, 2008, 10:49:22 AM »
That's good to hear. I had wondered if you had gone the way of the dodo bird.
