Author Topic: Civil 3D on a 64 bit OS  (Read 1565 times)
spittle
« on: May 14, 2008, 05:48:23 AM »
We're looking for a workstation that can cope with 3D Modelling using AutoCAD, rendering using 3DS Max and also the use of Civil 3D.
So how does Civils run on a 32bit OS? I understand it can by doing something, just not sure how. And would it impact on other 64bit applications?
Re: Civil 3D on a 64 bit OS
« Reply #1 on: May 14, 2008, 10:36:12 AM »
Build whatever OS you want; C3D will run on it. With 09 it appears they have the installation issues sorted, with other versions you will need alter the MSI to install on 64 bit OS.
