Author Topic: Capture Project Navigator Command for Drag/Drop for Xrefing  (Read 1665 times)
Guest
So I'm finally getting into the Project Navigator and one of the things I'd like to do is capture the event when you drag and drop a file from the Views tab into a drawing which then attaches that file as an xref.  I'd like to be able to automatically put the xref onto a company standard xref layer and lock it.
Any thoughts?  Anyone?!?
jbuzbee
Re: Capture Project Navigator Command for Drag/Drop for Xrefing
« Reply #1 on: May 09, 2008, 10:22:58 AM »
Matt,
Unfortunately dragging a file from the Project Navigator throws no trappable command.  I use a combination of the Xref Reactor and Modelspace Reactor.  The :VLR-beginAttach fires when the Xref is about to be attached, so I set my XREF layer current.  I couldn't get the :VLR-endAttach to work to re-set the clayer - the database wasn't "released" yet(?) so it wouldn't re-set clayer.  I had to go to the Modelspace Reactor to check when things are attached in modelspace (we rarely attach xrefs in pspace) <edit> it works on paper space too</edit>.  It's a kludge I know - but it works.  Let me know if you find out a better way:
;;; XREF Reactor ;
;;; Uses the modelspace reactor to re-set clayer ;
;;; Xref Call Back functions ;
;;; Begin Attach ;
(defun jb:beginAttach  (reactor vla-object /)
  (if (not (tblsearch "layer" "XREF"))(vla-add (vla-get-layers (vla-get-activedocument(vlax-get-acad-object))) "XREF"))
  (setq jb%XrefAttach T)
  (if (tblsearch "layer" "XREF")(jb:setclayer "XREF" T))
;;; Construct Xref Reactor ;
(defun jb::ConstructXrefReactor  (/)
  (if (= (type *jbXrefReactor*) 'VLR-Xref-Reactor)
    (progn (vlr-remove *jbXrefReactor*)
   (setq *jbXrefReactor* nil)))
  (if (/= (type *jbXrefReactor*) 'VLR-Xref-Reactor)
   (VLR-Xref-Reactor
     "jbTools Xref Reactor" ; Data associated with the editor reactor
     ;; call backs
      ((:VLR-beginAttach . jb:beginAttach)
               )) ;_ end of vlr-xref-reactor
  (if (not (vlr-added-p *jbXrefReactor*))
    (progn (vlr-add *jbXrefReactor*)
   (vlr-set-notification *jbXrefReactor* 'active-document-only)))
  (princ))
;;; load reactor ;
(if jb::ConstructXrefReactor
  (jb::ConstructXrefReactor))
;;; ModelSpace Reactor ;
(defun jb::StartResetReactor( / )
(if *jbMSReactor* (vlr-remove *jbMSReactor*))
(setq *jbMSReactor* (vlr-object-reactor (list (vla-get-modelspace (vla-get-activedocument(vlax-get-acad-object)))) nil '((:vlr-objectClosed . jb:resetXrefLayer))))
(if *jbPSReactor* (vlr-remove *jbPSReactor*))
(setq *jbPSReactor* (vlr-object-reactor (list (vla-get-paperspace (vla-get-activedocument(vlax-get-acad-object)))) nil '((:vlr-objectClosed . jb:resetXrefLayer))))
(defun jb:resetXrefLayer (owner reactor_object reactor_list  /)
  (if jb%XrefAttach
      (if dcl_HideErrorMsgBox
   (if (dcl_Form_IsActive jb001_00)
     (c:jb001_00_Refresh_OnClicked))
      (jb:resetclayer)
      (setq jb%XrefAttach nil)))
;;; load reactor ;
(if jb::StartResetReactor
  (jb::StartResetReactor))
« Last Edit: May 09, 2008, 11:55:30 AM by jbuzbee »
James Buzbee
Windows 8
« Reply #2 on: May 09, 2008, 11:22:58 AM »
Would this work for you?
[ http://www.theswamp.org/index.php?topic=15557.0 ]
It should fire no matter what space you attach an xref to.  I don't use the project navigator, so I didn't know how to test it out.
