(arxunload "geom3d.arx")
Okay, I see it now. You're taking bits and pieces and trying to put them together. That bit is from fatty, but in the code you posted since, the reason for it is missing. Step through the code piece by piece in the vlide. You'll quickly find the mistakes. Also, to make life easy on you you can group things like:
(setq width 3.625
height 7.250
cheight 7.625
It also works with command, but I like the way fatty used apply in this case. It doesn't work on setvar, which is why I came up with my functions listed above.
Just some pointers to help you along. I see that you have a long road ahead of you with a couple of items you've decided to take on. If you learn good practices now, it'll save you later.
Hi, mate
First of all change jjpt1 on jpt1 and height on jheight
Then you need to draw the polyline to be extruded
correctly, because of in you code this was drawn as
a self-intersected and you should't to extrude this
contour
Attach the sample picture of this polyline you want
to create
[And also I'm still avoid to use polar function for
parametric drafting (IMO only)]
~'J'~
I think you forgot to attach the picture.
Thank you,
Brad
I think he's asking you to attach something, but I could be wrong.
