here's the original copy and mirror if it helps, by the way i changed cab's plottabs routine to default to tabs and not plot to file all by myself and i'm sorta proud. see i'm figurin things out little by little
;;; CMI.lsp
;;; To Copy and mirror selected entities
;;; by Terrance Kesteloot and Rod Potter
;;; credit to Steve Smith Compuserve I.D.:72611,2544
(DEFUN ssmake (sslist)
(SETQ theset (SSADD))
(FOREACH ent sslist (SSADD (HANDENT ent) theset))
(DEFUN C:CMI ()
(SETQ cecho (GETVAR "CMDECHO"))
;;turn off command line echo
(SETVAR "CMDECHO" 0)
(SETQ theset nil
thelist nil
;;obtain last entity in database
(SETQ startent (ENTLAST))
(PROMPT "Entity(s) copy and mirror routine")
(PROMPT "\nCopying...")
;;create selection set
(SETQ sset (SSGET))
(SETQ bpt (GETPOINT "\nEnter base point for copy..."))
(COMMAND "copy" sset "" bpt pause)
(SETQ npt (GETVAR "LASTPOINT"))
;;build selection set list of newly copied entities
(SETQ thelist (LIST (CDR (ASSOC 5 (ENTGET startent)))))
(SETQ nextone startent)
(WHILE nextone
(PROGN
(SETQ nextone (ENTNEXT nextone))
(IF nextone
(SETQ thelist (CONS (CDR (ASSOC 5 (ENTGET nextone))) thelist))
;;list of entity handles for copied group
(SETQ thelist (CDR (REVERSE thelist)))
(ssmake thelist)
(PROMPT
"\nMirroring - select second point of mirror line for new objects..."
(COMMAND "mirror" theset "" npt pause)
;;turn off highlight
(SETVAR "highlight" 0)
;;reset command line echo to original state
(SETVAR "CMDECHO" cecho)
;;turn highlight back on
(SETVAR "HIGHLIGHT" 1)
;;clean finish
(PRINC)
