Author Topic: Prompting for hatch origin  (Read 1372 times)
whdjr
« on: May 05, 2008, 02:01:33 PM »
Does anyone know of a way to force the hatch command to prompt you for an origin with each use of the command?
Shinyhead
Re: Prompting for hatch origin
« Reply #1 on: May 05, 2008, 02:08:41 PM »
-bhatch;o;\
this runs it in command line mode.
make a macro and add all the specifics for the pattern and scale you want and it makes a nice button macro for your hatch routines.
Kate M
« Reply #2 on: May 05, 2008, 02:10:07 PM »
There's an "origin" option in the command line version, which I'm sure you could trigger with a macro or LISP...? Or combine it with the HPORIGIN variable...
whdjr
« Reply #3 on: May 06, 2008, 07:56:58 AM »
Thanks guys, and girls.  I'll see what I can come up with.
alanjt
  • Standby for witty remark...
« Reply #4 on: May 06, 2008, 08:20:09 AM »
for the few hatches i use, i just made a quick routine that will let me choose b/w the three hatches i use most (concrete, building, parking areas). then i can just pick the points it does all the hatching and layer placing for me (also sets the origin with the "pick point inside area to hatch"). it's all done through -hatch
Dropbox
