Author Topic: Capturing Named Views in Sset  (Read 14215 times)
ML
« on: May 05, 2008, 10:55:22 AM »
Hi
I have a drawing with about 73 named views.
I am working on some code here;
With some help (Thanks Bob!)
This part is working well
For Each Ent In Sset
 If TypeOf Ent Is AcadBlockReference Then
 Set BlkRef = Ent
 strName = BlkRef.Name
 ThisDrawing.SendCommand "MSLIDE c:\tempslide\" & strName & vbCr
  '*****MAKE SURE THE ABOVE FOLDER EXISTS*****
 End If
Next Ent
And all it is doing is grabbing each blkref (1 per view) in the drawing and making a slide for each one, using the blkfef.name as the slide name
However, I want to be able to grab the lower left and upper right points of each view in the drawing as the pick points for each slide. I have the below code written, I am getting prompted for each point, the view is getting zoomed to window which is critical for this but I can not get the views to be recognized as an entity type in the sset or  I am likely doing something wrong.
The other problem I am having is that by using the for each loop, I am ending up with a slide show.
All I want to do is to be prompted for each view, pick my points, then have the code assign the blockref name for that view as the name of each slide, then return the view back to the previous view and prompt for the next selection.
Also, with the views, each one needs to be restored (-view, r etc) in order for the frozen (views) layer state to be used.
Hope this makes sense?
Thanks!
M
Dim NView As AcadView
Dim Sset As AcadSelectionSet
Dim Ent As AcadEntity
Dim Pnt1 As Variant
Dim Pnt2 As Variant
Pnt1 = ThisDrawing.Utility.GetPoint(, "Pick First Point")
Pnt2 = ThisDrawing.Utility.GetPoint(, "Pick Second Point")
Set Sset = ThisDrawing.SelectionSets.Add("Sset")
Sset.Select acSelectionSetWindow, Pnt1, Pnt2
ZoomWindow Pnt1, Pnt2
 If TypeOf Ent Is AcadView Then
  strName = NView.Name
  ThisDrawing.SendCommand "-view" & vbCr & "r" & vbCr & strName & vbCr
  End If
Next Ent
ML
Re: Capturing Named Views in Sset
« Reply #1 on: May 05, 2008, 11:12:23 AM »
Ok,
With this code, I am almost have what I need
Sub CreateSlides()
  On Error Resume Next
  ThisDrawing.SelectionSets.Item("Sset").Delete
  Dim BlkRef As AcadBlockReference
  Dim strName As String
  Dim VName As String
  Dim sysFileDia As Integer
  Dim Pnt1 As Variant
  Dim Pnt2 As Variant
  sysFileDia = ThisDrawing.GetVariable("FILEDIA")
  ThisDrawing.SetVariable "FILEDIA", 0
    VName = NView.Name
    GoTo Continue
   End If
  Next Ent
Continue:
    Set BlkRef = Ent
    ThisDrawing.SendCommand "-view" & vbCr & "r" & vbCr & VName & vbCr
    End If
  Next Ent
  ThisDrawing.SetVariable "FILEDIA", sysFileDia
End Sub
Except it is still asking me what view I would like to restore; I am not sure how to pass that in, so when I do vslide, the slide is still showing the view and construction lines, I just want to see the blkref.
And at the end, I would like to restore the view to previous.
Can anyone get me over this last huddle?
M
Bob Wahr
« Reply #2 on: May 05, 2008, 12:51:35 PM »
Hadn't abandoned you, just busy.
Give this a look, needs to have the directory selection and text file bits added in.
Option Explicit
Sub MLides()
Dim objView As AcadView
Dim objViews As AcadViews
Dim varViewCen As Variant
Dim dblHgt As Double
Dim dblWdt As Double
Dim dblLLPt(0 To 2) As Double
Dim dblURPt(0 To 2) As Double
Dim objEnt As AcadEntity
Dim objBlkRef As AcadBlockReference
Dim objSelSet As AcadSelectionSet
Dim objSelSets As AcadSelectionSets
Dim strSldName As String
Set objViews = ThisDrawing.Views
For Each objView In objViews
  varViewCen = objView.Center
  dblHgt = objView.Height
  dblWdt = objView.Width
  dblLLPt(0) = varViewCen(0) - (dblWdt / 2)
  dblLLPt(1) = varViewCen(1) - (dblHgt / 2)
  dblLLPt(2) = 0
  dblURPt(0) = varViewCen(0) + (dblWdt / 2)
  dblURPt(1) = varViewCen(1) + (dblHgt / 2)
  dblURPt(2) = 0
  ZoomWindow dblLLPt, dblURPt
  Set objSelSet = ThisDrawing.SelectionSets
  For Each objSelSet In objSelSets
    If objSelSet.Name = "blkpick" Then
      ThisDrawing.SelectionSets.Item(strSet).Delete
    Exit For
    End If
  Next
  Set objSelSet = objSelSets.Add("blkpick")
  objSelSet.Select acSelectionSetWindow, dblllpnt, dblurpnt
  For Each objEnt In objSelSet
    If TypeOf objEnt Is AcadBlockReference Then
      Set objBlkRef = objEnt
      strSldName = objBlkRef.Name
      Exit For
    End If
  Next objEnt
  ThisDrawing.SendCommand "MSLIDE c:\tempslide\" & strSldName & vbCr
Next objView
Next objView
End Sub
Bob Wahr
« Reply #3 on: May 05, 2008, 01:52:34 PM »
Don't forget to change filedia.  I just did the views bit quickly and without testage, then flopped bits of the other stuff in.  Will definitely take some up cleanage.
ML
« Reply #4 on: May 05, 2008, 02:08:12 PM »
Hey Bob
I appreciate this
I had an idea that the center, height and width methods were the ticket but I was not making progress with it so I tried to change up.
Anyhow, I can see from trying the code that you posted that it is "going" to work; that is super cool!
It is creating the slides but not in the right directory, I am working on that part now, and I just put the filedia code in.
Also, at the end, I just put zoomprevious
So, let me see what I can do here
ML
« Reply #5 on: May 05, 2008, 03:21:33 PM »
Bob
I'm still having a problem making this work properly but I thought of one thing
Why do I need to restore each view?
How about if I just freeze the layer that all of the views are on in the beginning of the module? DUHHHH
That should work.
Bob, this is the error that is getting generated
Command: MSLIDE
Enter name of slide file to create <K:\AutoCAD\Work
Related\SlideTemplate-Labls-test>: c:\tempslide\AUTHORIZ_LT
C:\tempslide\AUTHORIZ_LT.sld already exists, do you want to replace it?
[Yes/No] <N>:
Document "K:\AutoCAD\Work Related\SlideTemplate-Labls-test.dwg" has a command
in progress.
Do you see where I am going wrong?
Also, I am not really sure that we need to even write out the list of blocknames; I could be wrong.
If we were creating a slide library from DOS using slidelib, then we would absolutely need that txt file
Here is the code so far:
ThisDrawing.SelectionSets.Item("blkpick").Delete
Dim intFile As Integer
Dim strFileName As String
  dblLLPt(2) = 0
  dblURPt(2) = 0
  Set objSelSets = ThisDrawing.SelectionSets
  objSelSet.Select acSelectionSetWindow, dblLLPt, dblURPt
      Exit For
    End If
  Next objEnt
  strFileName = "C:\tempslide\" & ThisDrawing.GetVariable("dwgname") & ".lst"
  '*****MAKE SURE THIS FOLDER EXISTS*****
      intFile = FreeFile
      Open strFileName For Append As #intFile
      Print #intFile, strSldName & ".sld"
      Close #intFile
 Next objView
  ZoomPrevious
ML
« Reply #6 on: May 05, 2008, 03:30:52 PM »
OK
Good and bad news
The good news is that I was not seeting the filedia correctly.
I fixed that and all of the slides got created
However, freezing the layer was not a good idea after all
If I did that, then what points are getting picked? DUHHH
So, if you can help me get each view to restore prior to the points getting picked, then I would say, it is a definite go
If I get some time here, I will try again as well
You definitely got the loop part working perfect
David Hall
  • Automatic Duh Generator
« Reply #7 on: May 05, 2008, 03:36:51 PM »
the points are being generated from the width and height of the view
ML
« Reply #8 on: May 05, 2008, 04:35:00 PM »
Yes, I know
So, you wouldn't think that freezing the layer would effect anything, right?
There is definitely a noticeable difference when you do a manual mslide and when you run this code with the layer frozen.
I'm not sure what the problem is.
I was thinking that may be I need to get rid of the zoomwindow part of the code?
If we use a zoomwindow, we would need something on screen to be picked, wouldn't we?
I would love to just freeze the layer and be done but the slides are not coming out with the height and width sizes.
I didn't really look close enough at Bob's code, I am assuming the math is correct
Bob Wahr
« Reply #9 on: May 05, 2008, 04:56:25 PM »
Yes, I know
The layer being frozen has nothing to do with anything.  It's possible that the views that you have saved are different than a window based off of your rectangles.  I haven't checked and don't have time right now to do so.  I'll try this one one more time...I've said it several times and other people have as well.  Step through your code line by line and see what's happening.  When the code I posted zooms a windows based off of view "1", does the screen look the same as if you manually restore the view?
If you get rid of the zoomwindow part of the code, what will happen?  Hint, mslide make a slide of the current display.  If you don't change the current display and make a slide, what do you get?  If you don't change it again, and make another slide, what do you get?
Maverick®
« Reply #10 on: May 05, 2008, 08:19:51 PM »
And now back for your posting pleasure.....  *ding ding*
Bryco
« Reply #11 on: May 05, 2008, 08:22:28 PM »
I'm not saying nuttin till I see my lawyer.
Glenn R
« Reply #12 on: May 06, 2008, 03:59:28 AM »
Was there any particular reason posts were removed from this thread?
hendie
« Reply #13 on: May 06, 2008, 05:03:21 AM »
am I correct in thinking that you have a named view for each block ?
Rather than messing about with named views, wouldn't it be easier to create a selection set of all blocks then loop through the selection set getting the bounding box of each block, and using those coordinates as your zoom window, then do the mslide thing ?
While X < SSet1.Count
    For Each Xblk In SSet1
        Inspt = Xblk.InsertionPoint
        Dim Zcenter(0 To 2) As Double
            Zcenter(0) = Inspt(0): Zcenter(1) = Inspt(1): Zcenter(2) = Inspt(2)
                                            Dim BboxSP As Variant
        Dim BboxEP As Variant
            Xblk.GetBoundingBox BboxSP, BboxEP
        Dim BboxP1(0 To 2) As Double
        Dim BboxP2(0 To 2) As Double
            BboxP1(0) = BboxSP(0): BboxP1(1) = BboxSP(1): BboxP1(2) = BboxSP(2)
            BboxP2(0) = BboxEP(0): BboxP2(1) = BboxEP(1): BboxP2(2) = BboxEP(2)
            ZoomWindow BboxP1, BboxP2
              ' DO THE MSLIDE BIT HERE
    Next Xblk
    X = X + 1
Wend
ML
« Reply #14 on: May 06, 2008, 10:06:10 AM »
Hey Hendie
Yes, that would make perfect sense and Bob had provided some good code to do just that but the problem seems to be that the bounding box doesn't give you enough space around the block and the slide doesn't come out as well; the block tends to get too close to the edges of the slide. If there were a way to increase the bounding box size, that would be great.
Initially with code Bob supplied, I was able to grab the center of each bounding box which really helped position the blocks into place; that was a big time saver but for this particular thing, I think that I would prefer to pick points.
I think I will just go back to my initial thought and that was to make a simple pick 2 points, then have the slide name = the blkref name.
I really don't have a problem grabbing a few points for each slide, it is typing the names for each that I can live without.
Thanks Hendie, I will still look at your code.
