PLEASE HELP!!!!
MODIFYING EXISTING TEXT1st- the text can be mtext, mostly the text will be plain text.
2nd - the command will be placed in a toolbar button, for example: (load "chgtxt");chtxt
3rd - yes I know how to perform theses tasks one at a time.. it gets old after hours and hours of repetitious attribute editing.
4th - please respond only if you can write the program.. criticism isn't going to solve anything... this is the program I want, period. Maybe in return, I can help you with something in Microstation.
humble cad man,,,,, mike....
I've tried searching the web and using ACAD help but I can't make this lsp happen.
I need a lsp program that will change existing text.......
Existing test is: PLAN EL.180'-0"
I want to select existing text to change.
Once selected, I want the selected text to be "UNDERLINED (adding %%u to the beginning- %%uEL.180'-0" )", the "STYLE" to change to "STD35E", the
"HEIGHT" to change to 3", the "LAYER" to change to "CY1".
An additional "help"
(but not required) would be to have the lsp read a "data file" to import the "STYLE, HEIGHT, and LAYER". (Underlining will always be required.)
Different "data files" for multiple requirements.
Sincerely,
Mike
