Author Topic: ssget question (setq & filters)  (Read 2822 times)
alanjt
  • Standby for witty remark...
« on: April 29, 2008, 12:57:58 PM »
is it possible to multiple filter setq an ssget?
for example:
(setq ss1 (ssget))
(setq ss2 (ssget ss1 '((0 . "INSERT"))))
(setq ss3 (ssget ss1 '((0 . "*TEXT"))))
Dropbox
Re: ssget question (setq & filters)
« Reply #1 on: April 29, 2008, 01:00:46 PM »
What are you trying to do?  If you want to select more than one type per ssget call, then just separate them with a comma.
(setq ss (ssget '((0 . "INSERT,*TEXT"))))
This will only select blocks (Insert) and any type of text (Text and MText).
alanjt
« Reply #2 on: April 29, 2008, 01:28:43 PM »
i was trying to help a friend combine 2 routines.
the first will convert selected text to mtext
the 2nd (i combined this into 2 for him already) will set the mtext with a width of zero and then textmask it.
problem is you have to ssget all the text, but when it's time to select text to set width and mask, the ssget setq isn't valid anymore because the newly created mtext exists in place of the old text.
that's why i was thinking you could just ssget the .....i just realized that i answered my own question.
how can the you even ssget the orig ssget if it is invalid.
oh well, nevermind.
still though, would it be possible to do what i'm asking though.
say you window a section in a drawing. you want it to then move all selected text to a specific layer, hatch to a specific layer, etc.
not really a big deal (i have no plans for something like this), now i'm just curious.
Dropbox
« Reply #3 on: April 29, 2008, 01:52:35 PM »
Once you make the mtext objects, then you can just add it to a selection set you create, because you can create a empty selection set.
« Reply #4 on: April 29, 2008, 02:59:19 PM »
As Tim said you would add the new Mtext to the existing Selection Set.
Use (ssadd ename ss)
alanjt
« Reply #5 on: April 29, 2008, 03:39:45 PM »
hmm, well back to the drawing board...
what's ename?
Dropbox
« Reply #6 on: April 29, 2008, 03:50:36 PM »
ename is the entity name, which is needed to add the entity to a selection set the way Alan shows.
« Reply #7 on: April 29, 2008, 03:50:57 PM »
Select an object using (car (entsel)) to see  :-)
alanjt
« Reply #8 on: April 29, 2008, 03:59:33 PM »
ah hah, i see.
Dropbox
