Author Topic: Mid point of a blockref  (Read 20513 times)
ELOQUINTET
Re: Mid point of a blockref
« Reply #30 on: April 28, 2008, 04:07:49 PM »
Hey this is nice. I'm currently having to place many blocks centered in a grid so this will come in handy for me as well. The only problem I was having is not being able to specify the midpoint between 2 points as my destination so I don't need to draw lines on my grid. I'm using 2002 and have created a button with this in it but it doesn't work:
_non;'cal (cur + cur)/2;
Bob Wahr
« Reply #31 on: April 28, 2008, 05:11:24 PM »
sub PickAWinner()
Dim pntOne as variant
dim pntTwo as variant
dim pntFriendsNose(0 to 2) as double
pntone=thisdrawing.getpoint(,"You can pick your friends: ")
pnttwo=thisdrawing.getpoint(,"You can pick your nose: ")
      pntFriendsNose(0) = (pntone(0) + pnttwo(0)) / 2
      pntFriendsNose(1) = (pntone(1) + pnttwo(1)) / 2
      pntFriendsNose(2) = (pntone(2) + pnttwo(2)) / 2
end sub
Bob Wahr
« Reply #32 on: April 29, 2008, 12:52:50 PM »
hEY mARK,
cHECK THIS OUT AND SEE IF IT'S WHAT YOU'RE AFTER.  sfcl, sorry
Option Explicit
Public Sub blkCent()
  Dim minExt As Variant
  Dim maxExt As Variant
  Dim strSetName As String
  Dim intGroup(0) As Integer
  Dim varGroup(0) As Variant
  Dim objSelSet As AcadSelectionSet
  Dim objSelSets As AcadSelectionSets
  Dim objBlkRef As AcadBlockReference
  Dim objEnt As AcadEntity
  Dim strName As String
  Dim sysFileDia As Integer
  Dim strFileName As String
  Dim strWriteLine As String
  Dim intFile As Integer
  Set objSelSets = ThisDrawing.SelectionSets
  strSetName = 1
  intGroup(0) = 0
  varGroup(0) = "insert"
  KillSet strSetName
  Set objSelSet = objSelSets.Add(strSetName)
  objSelSet.Select acSelectionSetAll, , , intGroup, varGroup
  sysFileDia = ThisDrawing.GetVariable("FILEDIA")
  ThisDrawing.SetVariable "FILEDIA", 0
  For Each objEnt In objSelSet
   If TypeOf objEnt Is AcadBlockReference Then
      Set objBlkRef = objEnt
      strName = objBlkRef.Name
      objBlkRef.GetBoundingBox minExt, maxExt
      ZoomWindow minExt, maxExt
      ThisDrawing.SendCommand "MSLIDE c:\tempslide\" & strName & vbCr
      strFileName = "C:\tempslide\" & ThisDrawing.GetVariable("dwgname") & ".lst"
      '*****MAKE SURE THIS FOLDER EXISTS*****
      intFile = FreeFile
      Open strFileName For Append As #intFile
      Print #intFile, strName & ".sld"
      Close #intFile
    End If
  Next objEnt
  ZoomExtents
  ThisDrawing.SetVariable "FILEDIA", sysFileDia
End Sub
Function KillSet(strSet As String)
  For Each objSelSet In objSelSets
    If objSelSet.Name = strSet Then
      ThisDrawing.SelectionSets.Item(strSet).Delete
    Exit For
    End If
  Next
End Function
ML
« Reply #33 on: April 29, 2008, 07:17:11 PM »
Hey Bob
I was at a company wide meeting for 2 days
Checking my e-mail from home
From looking at it, it looks good,  Iwill need to try it when I get in the office tomorrow
PS: Did you take a look at that vbsedit link?
Bob Wahr
« Reply #34 on: April 29, 2008, 07:30:10 PM »
Not yet.  Haven't had huge amounts of free time.
ML
« Reply #35 on: April 30, 2008, 10:30:34 AM »
Bob
I am back in the office
I think that is a good thing..hmmmmm   :-(
I have to do a few things this morning but I will definetely look at the code this afternoon
M
PS: Have you ever used the proper function? :)
hEY mARK,
ML
« Reply #36 on: April 30, 2008, 11:14:32 AM »
Bob
I still need to try it but I think you will like this, if you haven't used this method yet.
In the part of the code where it says, make sure folder exists...
Incorporate this code:
Note: First, Set a reference in VBA to
Microsoft Shell Controls and Automation
Sub TryMeBob ()
'Create new folder and get the path to the new folder
 Dim oShell As Shell32.Shell
 Dim oFolder As Shell32.Folder
 Dim oItems As Shell32.FolderItems
 Dim Item As Shell32.FolderItem
 Dim Path As String
 Set oShell = New Shell 'Get the ActiveX interface to shell32.dll
 Set oFolder = oShell.BrowseForFolder(0, "Select a path ", 0)
 If oFolder Is Nothing Then
  MsgBox "Path not selected... Exiting!!"
  Exit Sub
 End If
 Set oItems = oFolder.Items
 Set Item = oItems.Item
 Path = Item.Path & "\"
End Sub
ML
« Reply #37 on: April 30, 2008, 11:27:46 AM »
To try this code in a real example, we could write out our layers (txt file) to a folder that we create on the fly
M
Sub CreateFolderWriteLayers()
 Dim Path As String
  Exit Sub
 End If
'For demonstration, write out your ACAD drawing layers to a .txt file (using drawing name = filename) and place it in your new folder
 Dim MyFile As Variant
 Dim Dwgname As String
 Set FSO = CreateObject("Scripting.FileSystemObject")
 Set WshNetwork = CreateObject("WScript.Network")
 Dwgname = UCase(Left$(ThisDrawing.Name, Len(ThisDrawing.Name) - 4))
 Set MyFile = FSO.CreateTextFile(Path & Dwgname & ".Txt", True)
 For Each Layr In ThisDrawing.Layers
  MyFile.WriteLine Layr.Name
 Next Layr
 MyFile.Close
 End Sub
ML
« Reply #38 on: April 30, 2008, 03:10:57 PM »
BOB
I tried your code for making the slides
Awesome!!!!!!!!
Now, I see that the lst (text file) of each slide was created with all of the slides in the directory C:\tempslide
However I did not do a vslide on any of them yet.
Have you created a slide library with them?
If so, how did it look?
I need to examine your code further.
OK, I think what you did was used the bounding box of each blkref to create the slides;
If so, that will not work for me.
I need to get the extmin and extmax of each viewport as then are defining my boundaries for each slide.
Did you get that template that I sent to you?
As far as naming the slides, the was perfect, using the blkref names.
Also, I have seen freefile but I never quite understood how it worked?
Thanks!
Bob Wahr
« Reply #39 on: April 30, 2008, 03:34:18 PM »
Yea, got t and used it.  Didn't see any viewports which is why I didn't use them.  What you've got are named views, not viewports.  Different animals.  Do you want the slides named the same as the block name, or the view name?
ML
« Reply #40 on: April 30, 2008, 03:58:11 PM »
I'm sorry
The named views are on layer temp, they may have been frozen, I apologize
Naming the slides with the blockrefs names is perfect but the points need to be grabbed from the min and max of each named views
Some people may use rectangles, that is fine too
Where the named views will come in handy is when we write the script.
Because we can do something like this:
view
r
3
mslide
Blkref name
So, if we go left to right, top to bottom, and grabbed the min and max of each named view, that would be perfect.
Then
the script is saying
restore
view 3
mslide
blkref.name
There is a good reason why I prefer named views or rectangles; the blocks just look a lot more centered that way.
I thought it was a good idea to use named views so that we have a name to grab when writing out scripts
If we are interating through the named views, then it will be # 1 through whatever
What do you think?
ML
« Reply #41 on: April 30, 2008, 04:01:27 PM »
Bob
Forget this line
If the views are named in numeric order, then it will be fine
The code will just iterate through the named view collection accordingly
Bob Wahr
« Reply #42 on: April 30, 2008, 04:07:51 PM »
It's not hard to name them by the view name, or the block name, just need to know which you prefer.  I don't really see the point in scripting this, seems as easy, easier actually, just to make them programatically.
ML
« Reply #43 on: April 30, 2008, 04:12:24 PM »
Yes, yes
You have a great point as you just demonstrated
Why script them when you can do it as you previously demonstrated.
I would definitely prefer the the blkref name as the name of the slide
For the text file, I did this:
strFileName = "C:\tempslide\" & Dwgname & ".txt"
Just to get the extension out of the text file name; that is so minor though
Bob Wahr
« Reply #44 on: April 30, 2008, 05:00:54 PM »
what do you think about this?
Option Explicit
  Dim pntLL(0 To 2) As Double
  Dim pntUR(0 To 2) As Double
  strSetName = 1
  intGroup(0) = 0
  KillSet strSetName
      pntLL(0) = ((minExt(0) + maxExt(0)) / 2) - 67.93
      pntLL(1) = (minExt(1) + maxExt(1)) / 2 - 43.04
      pntLL(2) = (minExt(2) + maxExt(2)) / 2
      pntUR(0) = ((minExt(0) + maxExt(0)) / 2) + 67.93
      pntUR(1) = (minExt(1) + maxExt(1)) / 2 + 43.04
      pntUR(2) = (minExt(2) + maxExt(2)) / 2
      ZoomWindow pntLL, pntUR
      intFile = FreeFile
      Close #intFile
    End If
  Next objEnt
  ZoomExtents
End Sub
    Exit For
    End If
  Next
End Function
