I am once again playing around with the survey functionality of C3D. We spent all of this money on the product and every few months, I start get a wild bug up my a** and decide to try and give the survey portion a go again. I have installed the survey extension pack and created a practice traverse. I tried to define a traverse from a figure and it doesn't fill in any of the angles or distances. Is this routine buggy or am I doing something wrong. Here is my procedure:
(see below for a picture of the traverse - purple line is known good line, cyan is the survey figure)
This is a basic traverse with points 13 & 14 being known good points and points 15 through 17 being uncertain. Point 18 is the final forsight back to point 14.
I create my network, then I add the known good points to the network as control points (in this instance, points 13 and 14) and all other points as non-control points (point 15 through 18). Point 18 is the field measured shot back to point 14.
I insert the network into the drawing then drawing my pline. Starting at point 14 and ending at point 17. I then create a figure from this pline. Next, I select to define traverse stations from figure. Initial Station set to 14, initial backsight 13 and final foresight as 18.
I end up with a traverse listing all of the stations but not populating any of the angles or distances. So basically, I am getting something useless that cannot be adjusted.
Basically, I want to adjust this traverse to close back to point 14. Could someone please tell me what I am doing wrong. Thank you.
