Author Topic: Font problem or not ?  (Read 9198 times)
craigr
Re: Font problem or not ?
« Reply #15 on: April 24, 2008, 12:54:03 PM »
It works fine on my 2008 LT.
I know that from our experience, when we swiitched to TTF, our dwg navigation did slow, but that was on far inferior machines than what we have now.
On a second note, what language is that in the dwg?
My guess is French, am I right?
craigr
Crank
« Reply #16 on: April 24, 2008, 01:53:12 PM »
On a German forum I found a arial.shx made by Stefan Wickel.
See the attached file.
grasu666
« Reply #17 on: April 24, 2008, 02:56:30 PM »
I also just found this link on the Autodesk site... I hope this one might help
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5029605&linkID=9240617
Tried also :( , no improvment. My problem is with pan at specific zoom, not with slow start-up. I also tried using bold.shx but same thing/problem.
@craigr : Language is romanian, and I dont think computer performance is my bootleneck here. I've tried this file on a quad core Q6600 + 2 GB RAM , 320 GB Seagate, 8500GT video card(tried also on my other computer wich is :E6300@2800 Ghz, 2x1GB DDR2@1000 Mhz, 7600GT video card.
« Last Edit: April 24, 2008, 03:01:04 PM by grasu666 »
M-dub
« Reply #18 on: April 24, 2008, 03:37:46 PM »
I'm confused (Surprise, Surprise).  Who's asking the question here?  Seems we've got two different people with the same problem?
craigr
« Reply #19 on: April 24, 2008, 03:40:15 PM »
Performance is definately not the problem with a machine like that - (I'm Jealous).
Language - No offense meant, I have always been facinated by other languages (& Accents).
craigr
Atreides
« Reply #20 on: April 24, 2008, 03:43:07 PM »
My bad, I didnt realised I'm logged with my brothers account:).
M-dub
« Reply #21 on: April 24, 2008, 03:44:02 PM »
Not a problem!  Just seemed strange is all...
Carry on!  :)
jonesy
  • SuperMod
« Reply #22 on: April 24, 2008, 03:50:22 PM »
Not a problem... I was getting confused. I thought there was 2 people asking similar questions on the same day.
OK, did you try the font that Crank has attached?
ReneRam
« Reply #23 on: April 24, 2008, 06:22:30 PM »
Not giving a solution, but just adding some information.
During the past years, depending on the version of AutoCAD and on the different configurations, not only in my company, I have noticed that programs like CorelDraw or similar ADD/Overwrite TTF fonts that become available in AutoCAD.
Last but not less important, I know a big company here in Italy that has different software configurations and have experienced problems with the TTF opening the same drawing with AutoCAD 2005 and with AutoCAD Map 3D 2008; the strange thing was that both computers had the same font, don't remember it at the moment, but in ACAD2005 it was listed with a different font name that the one displayed in MAP2008, although the TTF file was the same.
Atreides
« Reply #24 on: April 25, 2008, 02:26:09 AM »
Tried it, it's definitely an improvment, but unfortunally I cant present myself to a customer with those kind of fonts(I dont think they will look nice when its plotted).
jonesy
  • SuperMod
« Reply #25 on: April 25, 2008, 05:25:30 AM »
Then the only work around I can suggest is to use a similar font until you are ready to print, then change it once the drawing is complete, then plot.
Sorry I couldnt help you further, so, unless anyone else has any better suggestions, it looks like that may be the easiest wasy of working.
« Reply #26 on: April 25, 2008, 08:30:43 AM »
Tried it, it's definitely an improvement, but unfortunately I cant present myself to a customer with those kind of fonts(I don't think they will look nice when its plotted).
You need to try a plot before you make that decision. The font is filled in because the line weight causes an overlap of the interior lines you see when you zoom in that close.
M-dub
« Reply #27 on: April 25, 2008, 08:52:52 AM »
This might only be a band-aid fix, but I'll throw it out there anyway.
What about creating two macro buttons to toggle between a .ttf and an .shx?  Quick and easy... Cheap and Dirty?  Call it what you want, but I think it would suffice...
^C^C-Style;Standard;arial.ttf;;;;;;
^C^C-Style;Standard;txt.shx;;;;;;;
Atreides
« Reply #28 on: April 25, 2008, 12:47:23 PM »
I'll try this thing, and come back with results :).
Atreides
« Reply #29 on: May 06, 2008, 03:24:32 AM »
Thanks to all for your answers. I guess I'll have to use differents fonts at least untill printing.Can be closed.
