(command "._CHANGE" ps1 "" "_P" "_C" "_BYLAYER" "_LT" "_BYLAYER" "")
How can 10 lines of code be so unique that is is protected?After all for a simple problem there are a finite number of solutions. Having never seen that solution it is very likely that on your own you would compose a code similar if not exactly like that solution.
