A tech came today with a question and I didn't have the answer.
They were inputting a deed as polylines into C3D. The deed doesn't close (when do they ever) by about 0.08'. How would you get an inverse report and a general closure report on this polyline. She tried converting it into a parcel but it didn't create the parcel because of the 0.08' gap in closure.
What are you guys doing to handle this. In the past, I would just add an additional segment, create my closed parcel, run a report on it and then manually calculate my precision. A lot of steps for an expensive piece of software. And in the report that is being generated, you aren't getting an accurate error of closure nor are you getting a *REAL* inverse because you fudged the parcel to get it closed.
Suggestions?
