Hope this helps, it should be fairly secure once compiled into a vlx.
(if (equal (get-password "Please Enter Password") "YOUR-PASS")
; do stuff
(prompt "\nSorry wrong password)
; GET-PASSWORD - Dialogue box for standard password entry. *
; ============ Arguments: PRMPT = Prompt for top of dialogue box *
; Example: (get-password "Please Enter Password") *
(defun GET-PASSWORD ( PRMPT / dclname tempname filen dclid ret)
(setq dclname (cond ((setq tempname (vl-filename-mktemp "GET-PASSWORD.tmp") filen (open tempname "w"))
(foreach stream '( "passdlg : dialog { key = \"TITLE\"; label = \" \";\n"
" : boxed_column {\n"
" : edit_box { label = \"Password:\"; edit_width = 20; key = \"password\"; password_char = \"*\";}\n"
" }\n"
" spacer_1;\n"
" ok_cancel;\n"
" }\n")
(princ stream filen)
(close filen)
tempname
(setq dclid (load_dialog dclname))
(if (not (new_dialog "passdlg" dclid))(progn (alert "Dynamic Dialogue Extraction Failed.")(exit)))
(if PRMPT (set_tile "TITLE" PRMPT))
(mode_tile "password" 2)
(action_tile "password" "(setq ret $value)")
(start_dialog)
(unload_dialog dclid)
ret
