Author Topic: Boolean operations fouled up in 2009?  (Read 3366 times)
Josh Nieman
Re: Boolean operations fouled up in 2009?
« Reply #15 on: April 18, 2008, 04:16:11 PM »
Wow, yea... happens in 2008 as well, for me.
I'm going to start with a fresh Drawing1.dwg and see if I can do it using a clean drawing and 'clean' solids.
*edit* Follow-up
yep... I used two boxes via the BOX command, and one extruded rectangle in a clean slate... same problem.
That's just... funny-annoying.
