Well in 2009, there's problems, there Pesci.
Basically (man I wish I had a screen-cap software right now) I use the command "Intersect" on three objects. Two objects are free standing, and the third touches the first two.
Think of two plus signs next to eachother, as if the horizontal line was one object ++
I use this example, because that's basically what I have. Think of that dual-plus sign extruded off your screen.
Now, when I do an intersect in the original drawing, nothing happens. By that, I mean no change to the display occurs, no objects are modified. In fact, when you select the objects, it still shows (3 Objects in the Properties). Upon further investigation... the right-hand vertical line represented in the plus sign example, has been union'd to the other two objects, but the other two objects remain.
I WBLOCK'd out the three objects and opened that file. I showed three objects, but one of the objects was the appropriate result. Let me repeat this in different words. I WBLOCK'd the three objects, and DIFFERENT SOLIDS were made. One solid was the expected end result that should happen when running intersect on three objects. One solid was the horizontal line. One object was the left-hand vertical line.
I copy the proper object, thinking I encountered something funny ha-ha, and paste it into my original drawing at the proper coordinates. IT REVERTED BACK TO THE CRAPTASTIC scenario I originally described. It was a single object, which encompassed all three, as if I ran "UNION" rather than "INTERSECT"
I'm going nuts here with 2009.
I'm off to the extra computer to do my edits, then saving it, and reopening it in 09. BRB.
