Author Topic: XPLODE command  (Read 2483 times)
AVCAD
XPLODE command
« on: August 26, 2004, 03:51:44 PM »
I am trying to use the XPLODE command in a script, button, lisp file...it wont work in anyof them....
The command keeps stopping in the middle of it....
Command: XPLODE
Select objects to XPlode.
Select objects: ALL
39 found
Select objects:
39 objects found. 37 invalid.
XPlode Individually/<Globally>: G
Enter an option
[All/Color/LAyer/LType/LWeight/Inherit from parent block/Explode] <Explode>: ALL
New Color [Truecolor/COlorbook] <BYLAYER>: BYLAYER
Enter new linetype name for exploded objects <ByLayer> : BYLAYER
Enter new lineweight <ByLayer>: BYLAYER
Enter new layer name for exploded objects <0>:
*Invalid selection*
Expects a point or
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/CLass
Select objects:
That is where it stops...even though in the scr it is suppose to select ALL and then continue....
any idea???
daron
XPLODE command
« Reply #1 on: August 26, 2004, 11:34:26 PM »
Try typing a different option, like I for inherit and where it's stopping typing all. That seems to be where it's asking for you to select an object. I'm not sure what the other all is for. Seems misleading on the surface.
XPLODE command
« Reply #2 on: August 27, 2004, 11:22:40 AM »
Try this:
^C^C_ai_selall;.explode;
I tried the select all over here and it didn't work either, so I use CNTRL+A then explode.  :D
Your noun/verb selection will need to be checked in options for this to work.
This works as well:
^C^C_ai_selall;.xplode;global;all;;;;;
