Author Topic: ( Acad '06 ) Select File dialog strangeness  (Read 5247 times)
Re: ( Acad '06 ) Select File dialog strangeness
« Reply #15 on: April 18, 2008, 06:49:41 PM »
If you change the order to the way you want it & then hold down Ctrl while you open a drawing the order should stick for next time. Works in ADT 2006.
now THAT is a great tip !
