Test this:
;; CAB 04.25.08
;; Combine blocks using combined names
;; Dependant on block name starting with plan_PK-07 or elev_PK-07
(defun c:CBlock (/ bent bent2 bname bname2 pt ss LibPrefix *error*)
(defun *error* (msg)
(if (not
(member msg '("console break" "Function cancelled" "quit / exit abort" "")))
(and bent (redraw (car bent) 4))
(and bent2 (redraw (car bent2) 4))
) ; end error function
(setq LibPrefix "PK-07")
(and
(setq bent (entsel "\nSelect main block for name."))
(null (redraw (car bent) 3))
(setq bname (cdr (assoc 2 (entget (car bent)))))
((wcmatch bname "_*") ; plan view
(setq bname (vl-string-subst "group_" "_" bname))
(setvar "clayer" "V-EXTRACT-NEW")
((wcmatch bname "elev_*")
(setq bname (vl-string-subst "elevgroup_" "elev_" bname))
(setvar "clayer" "0")
(setq bname (vl-string-subst "_" "." bname) ; change . to _
bname (vl-string-right-trim "_M" bname) ; remove M & _
(setq bent2 (entsel "\nSelect sub block for name."))
(null (redraw (car bent2) 3))
(setq bname2 (cdr (assoc 2 (entget (car bent2)))))
((wcmatch bname2 "_*")
(setq bname2 (vl-string-subst "" (strcat "_" LibPrefix) bname2)) ; remove the prefix
((wcmatch bname2 "elev_*")
(setq bname2 (vl-string-subst "" (strcat "elev_" LibPrefix) bname2)) ; remove the prefix
(setq bname2 (vl-string-right-trim "_LRM" bname2) ; remove suffix _, L, R, M
bname2 (vl-string-left-trim "_." bname2) ; remove prefix _ or .
bname (strcat bname "_" bname2)
(princ (strcat "\nNew Block Name \"" bname "\""))
(princ "\nSelect objects to makup the new block.")
(setq ss (ssget))
(setq pt (getpoint "\nPick Insert point."))
(if (and ss pt (listp pt))
(if (tblsearch "BLOCK" bname)
(alert "Block Combo already exist.")
(command "-block" bname "non" pt ss ""
"-insert" bname "non" pt "" "" "")
(*error* "")
