Author Topic: Trouble purging a dimstyle  (Read 8360 times)
jonesy
  • SuperMod
« on: April 15, 2008, 06:01:10 AM »
Well guys, by the time I get this job up and running smoothly, I'll either be bald or completely grey.
I have a new problem regarding drawing sheets today  :-)
The drawing I have attached has a dimstyle within the drawing. Trouble is, I cannot find any objects creates by the dimscale to erase them, I have a suspicion it could be something to do with the proxy message I get when saving the file (but I could be mistaken).
I need to get rid of the dimstyle, does anyone have any ideas how I could achieve this?
I've purged and repurged the drawing, I've gone into the block editor and erased everything, then purged, but the dimstyle is still there.
Many thanks in advance
T :)
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: Trouble purging a dimstyle
« Reply #1 on: April 15, 2008, 07:18:24 AM »
This dwg-file has proxy, which referenced to dimstyle SCALE 1 DASH-DOT. I've remove all proxies and can purge this dimstyle.
jonesy
  • SuperMod
« Reply #2 on: April 15, 2008, 07:45:07 AM »
Thank you so much Alexander. I had my suspicions that it was the proxy.
If you dont mind sharing, how did you get rid of it? I had tried saving it to a r14 version, and a dxf, but it wouldnt go.
« Reply #3 on: April 15, 2008, 08:00:04 AM »
Tracey, R12 DXF will remove all proxy data, but it also removes MText and converts stacked dimensions to blocks and pretty well strips out lots of other stuff, but otherwise keeps the geometry intact. If all you need is the geometry and can make preparations for the mtext, you can R12 DXF and remove all of the proxy data.
jonesy
  • SuperMod
« Reply #4 on: April 15, 2008, 08:45:41 AM »
Thanks Keith
I "thought" I'd tried it as r12, but I guess it must've been a newer version dxf I saved as because it still came up with the proxy dialog box. (Either that or operator error)
Anyway, thanks for the help both of you :)
T :)
Alexander Rivilis
« Reply #5 on: April 15, 2008, 08:53:04 AM »
Try my utility ExplodeProxy (commands _EXPLODEALLPROXY and _REMOVEALLPROXY after loading ExplodeProxyNNNN.arx): http://www.maestrogroup.com.ua/support/ExplodeProxy.zip
« Last Edit: April 15, 2008, 08:59:04 AM by Alexander Rivilis »
jonesy
  • SuperMod
« Reply #6 on: April 15, 2008, 09:00:06 AM »
Thanks Alexander. I'll have to download that at home and bring it in to my workplace... IT restrictions mean I cannot download it :(
Alexander Rivilis
« Reply #7 on: April 15, 2008, 09:15:46 AM »
I can attach it.
jonesy
  • SuperMod
« Reply #8 on: April 15, 2008, 09:38:54 AM »
Thanks so much Alexander,
Unfortunately I cannot even download that zip file from work. :(
Alexander Rivilis
« Reply #9 on: April 15, 2008, 09:54:08 AM »
Which format of file you can download?
jonesy
  • SuperMod
« Reply #10 on: April 15, 2008, 10:05:05 AM »
Very few formats unfortunately, and I'm not sure which. We dont now until we get a webpage telling us we're doing something we shouldnt be doing.
I will be going home in 15 minutes, so I can download from home, and bring it into work tomorrow.
Thanks for ALL your help. Very much appreciated
jonesy
  • SuperMod
« Reply #11 on: April 16, 2008, 04:43:42 AM »
Morning Alexander.
I tried your arx file, but it didnt delete any proxy objects. (Could you check that I'm doing it right please)
Command: _EXPLODEALLPROXY
Удалено Proxy: 0 Новых объектов: 0
Command: Command: Unknown command "COMMAND:".  Press F1 for help.
Command: _REMOVEALLPROXY
Последняя метка объекта: <117D2>
Всего найдено 0 proxy-объектов
Всего удалено 0 proxy-объектов
Для проверки ошибок выполните команду _AUDIT
Command:
Command:
Is arx version dependant? I am working on 2008 Map, so would that be different?
Once again, thanks for your help
Tracey
Alexander Rivilis
« Reply #12 on: April 16, 2008, 04:51:55 AM »
Morning Alexander.
Command:
Command:
Tracey
Explodeproxy2007.arx is working in AutoCAD 2007 as well as 2008 and 2009. If you are using Map there is no proxies objects. I remove proxies in "pure" AutoCAD. Sorry for russian messages - I has not time to translate it in english.
jonesy
  • SuperMod
« Reply #13 on: April 16, 2008, 05:02:21 AM »
Our map has all the map functionality removed by routines when we first load the program. So we are using it as vanilla ACAD, but as you saw the proxys are AEC(?) proxy objects which I cannot delete.
Because the one I posted was part of a multiple tab template, the whole template has now been "infected"
Alexander Rivilis
« Reply #14 on: April 16, 2008, 05:09:41 AM »
Post full template or:
1) set DEMANDLOAD to 0
2) restart AutoCAD
3) open template
4) _EXPLODEALLPROXY and _REMOVEALLPROXY
5) _PURGE
6) set DEMANDLOAD to 3
7) save template
