Author Topic: Block select Lisp needed...  (Read 17453 times)
  • Custom Title
« Reply #30 on: August 27, 2004, 09:20:21 AM »
Details;
1 block (block1) 3 attributes
10,000 insertions of block1.
2,500 contain the string ("E") in one on the attributes we are looking for.
SMadsen (SUBST method)
Elapsed time: 3.2030 seconds
MThomas
Elapsed time: 2.0160 seconds
SMadsen
« Reply #31 on: August 27, 2004, 09:23:39 AM »
Wow, slower? Hmmm
Ok, I'll bite the dust :D
Thanks Mark
  • Custom Title
« Reply #32 on: August 27, 2004, 09:45:32 AM »
Just to make sure I ran it again, without closing the dwg, and the results ..........
Command: (gc)
nil
Command:
Command: (LOAD "D:/home/src/AutoLisp/Working/chg-blk-to-lay.lsp") ATTLAY
Command: (attlay)
Elapsed time: 3.2340 seconds
Command: change
Select objects: Specify opposite corner: 2500 found
Select objects:
Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness]: la
Enter new layer name <0>: blocks
Command: (gc)
nil
Command: (gbwa)
Elapsed time: 2.1410 seconds
SMadsen
« Reply #33 on: August 27, 2004, 10:14:57 AM »
Quote from: Mark Thomas
Just to make sure ...
Yeah right .. just rub it in   :lol:
« Reply #34 on: August 27, 2004, 10:18:04 AM »
So does that mean USA takes the gold?
(Pthhhht! "Denmark" ...like they even had a chance?!")
SMadsen
« Reply #35 on: August 27, 2004, 10:20:16 AM »
Oh USA always think they are entitled to the gold, whether they deserve it or not .. didn't you know?  :twisted:
  • Custom Title
« Reply #36 on: August 27, 2004, 10:22:15 AM »
It would be interesting to see how well VBA did on this? Any takers ..................
« Reply #37 on: August 27, 2004, 10:26:06 AM »
Pthhht! 'Knew it', Hell that expectation comes second nature by now.
SMadsen
« Reply #38 on: August 27, 2004, 10:36:05 AM »
Quote from: Se7en
Likewise :D
daron
« Reply #39 on: August 27, 2004, 11:58:28 AM »
Quote from: SMadsen
I thought that was Russia. I'm surprised they'd been so well behaved about it this year.
« Reply #40 on: August 27, 2004, 12:00:03 PM »
Ok folks you asked for it......
My testing results on a drawing with .....
one block "block1" , 10000 insertions
three attributes, each with a value
2500 blocks had one value with an "e" or "E"
(attlay)
2.1870 seconds
(gbwa)
2.0641 seconds
VBA code below
0.5939 seconds
BUWAHAHAHAHAHAHAHAHAHA
Sub ChBlLayer()
 Dim SS As AcadSelectionSet
 Dim ATTS As Variant
 Dim Code As Variant
 Dim Data As Variant
 Dim GCode(1) As Integer
 Dim GData(1) As Variant
 Dim BRef As AcadBlockReference
 Dim STime As Variant
 Dim ETime As Variant
 STime = TimeIt
 GData(0) = "INSERT"
 GData(1) = 1
 GCode(0) = 0
 GCode(1) = 66
 Code = GCode
 Data = GData
 Set SS = ThisDrawing.SelectionSets.Add("test2")
 SS.Select acSelectionSetAll, , , Code, Data
 For Each BRef In SS
  ATTS = BRef.GetAttributes
  For X = 0 To UBound(ATTS)
  If InStr(1, ATTS(X).TextString, "e", 1) > 0 Then
   BRef.Layer = "0" 'put me on this layer
   X = UBound(ATTS) + 1
  End If
  Next X
 Next BRef
 SS.Delete
 ETime = TimeIt
 MsgBox ETime - STime & " Seconds"
Function TimeIt()
 Dim CTIME As Variant
 CTIME = ThisDrawing.GetVariable("MILLISECS")
 TimeIt = CTIME / 1000
End Function
SMadsen
« Reply #41 on: August 27, 2004, 12:34:49 PM »
What's that? TimeIt = CTIME / 10000  ?
Oh, you edited it!  :twisted:
« Reply #42 on: August 27, 2004, 01:26:44 PM »
nope ... never did...
just accept defeat with a grin ...
