One Line Diagram via copy F1
T-Square:
Hello All,
Does anyone have a lisp routine that allows you to consecutively select existing blocks and copy it to another location in a one line format?
Thanks in advance!
T-Square:
It's a start...
--- Code: ---(defun c:ONELINE (/ DIMSC INSPT BLK1 BLKENT BLK2)
(setvar "attreq" 0)
(setq DIMSC(getvar "dimscale"))
(setq INSPT(getpoint "\nSelect One Line Start Point: "))
(setq BLK1(entsel "\nSelect A Block: "))
(if BLK1
(setq BLKENT(entget (car BLK1)))
(if (= (cdr (assoc 0 BLKENT)) "INSERT")
(setq BLK2(cdr (assoc 2 BLKENT)))
(command ".insert" BLK2 INSPT DIMSC DIMSC 0)
);progn
(princ "\nNot A Block... Please Select Again: ")
);if
);progn
(princ "\nNothing Selected... Please Select Again: ")
);if
--- End code ---
T-Square:
Getting there...
--- Code: ---(defun c:ONELINE (/ DIMSC BLK1 BLKENT BLK2)
(setvar "attreq" 0)
(while
(if BLK1
(setq INSPT(list (+ (car INSPT) (* DIMSC 0.75)) (- (cadr INSPT) 0.0)))
);progn
);if
);progn
);if
);while
--- End code ---
T-Square:
Works for me... Anyone care to critique... additions... subtractions?
"INITERR" & "RESET" are functions within my local error trap loaded at startup.
(INITERR)
(setvar "CMDECHO" 0)
(command ".undo" "end")
(command ".undo" "m")
(setvar "CECOLOR" "bylayer")
(setvar "CELTYPE" "bylayer")
(setvar "CELWEIGHT" -1)
(setvar "SNAPMODE" 0)
(setvar "ATTREQ" 0)
(graphscr)
(GETSPACE)
(MAKEONELINELAYER)
(while
(if BLK1
(RESET)
;;;;;;;;;;Sub Functions
(defun GETSPACE (/)
(if (and (equal (getvar "TILEMODE") 0)
(equal (getvar "CVPORT") 1)
(setq CSPACE 1);paper space
(setq CSPACE 0);model space.
(if (= CSPACE 1)
(setq DIMSC 1.0)
(setq DIMSC(getvar "DIMSCALE"))
(defun MAKEONELINELAYER (/)
(setq LAY "YOURLAYERHERE")
(if (not (tblsearch "layer" LAY))
(command ".-layer" "thaw" LAY "on" LAY "unlock" LAY "make" LAY "color" "1" LAY "lt" "continuous" LAY "")
(princ (strcat "\nLayer " LAY " Already Exists... Layer Un-Changed... "))
(setvar "clayer" LAY)
--- End code ---
Couple of things I am not sure if I want to tackle. Not all of my blocks are inserted about the center of the block. Thus, some are slightly off the center of the one line. Oh, and I can't remember how to keep the loop going if "Nothing Selected... Please Select Again" comes up.
CAB:
I made a few changes, not knowing exactly what you are trying to acheave.
; (INITERR) ; ???
;| turned off during debug
(setvar "ATTREQ" 0)
(graphscr) |;
(setq DIMSC (GETDIMSCALE)) ; CAB
(MAKEONELINELAYER "YOURLAYERHERE") ; CAB
(if (setq INSPT (getpoint "\nSelect One Line Start Point: "))
(while
((null (setvar "ErrNo" 0))) ; reset var, cond never stops here
((and (setq BLK1 (entsel "\nSelect A Block: "))
(setq BLKENT (entget (car BLK1)))
(setq BLK2 (cdr (assoc 2 BLKENT)))
(setq
INSPT (list (+ (car INSPT) (* DIMSC 0.75)) (- (cadr INSPT) 0.0))
((= (getvar "errno") 52) (prompt "\nUser Quit.")) ; Exit on ENTER key
(BLK1 (princ "\nNot A Block... Please Select Again: "))
((princ "\nNothing Selected... Please Select Again: "))
;; note that princ returns not nil
;; using prompt will cause an exit from the loop
; (RESET) ; ???
(defun GETDIMSCALE () ; CAB revised
1.0 ; paper space
(getvar "DIMSCALE") ; model space.
(defun MAKEONELINELAYER (LAY /) ; let the calling routine supply the layer
;; (setq LAY "YOURLAYERHERE")
;;(setvar "clayer" LAY) <---<< change this
(command "._Layer" "_Thaw" LAY "_On" LAY "_UnLock" LAY "_Set" LAY "")
; to this
--- End code ---
Navigation
[0] Message Index
[#] Next page
Go to full version
