Author Topic: One Line Diagram via copy F1  (Read 3529 times)
T-Square
« on: April 06, 2008, 03:47:08 PM »
Hello All,
Does anyone have a lisp routine that allows you to consecutively select existing blocks and copy it to another location in a one line format?
Thanks in advance!
T-Square
Re: One Line Diagram via copy F1
« Reply #1 on: April 06, 2008, 05:03:36 PM »
It's a start...
(defun c:ONELINE (/ DIMSC INSPT BLK1 BLKENT BLK2)
(setvar "attreq" 0)
(setq DIMSC(getvar "dimscale"))
(setq INSPT(getpoint "\nSelect One Line Start Point: "))
(setq BLK1(entsel "\nSelect A Block: "))
(if BLK1
(setq BLKENT(entget (car BLK1)))
(if (= (cdr (assoc 0 BLKENT)) "INSERT")
(setq BLK2(cdr (assoc 2 BLKENT)))
(command ".insert" BLK2 INSPT DIMSC DIMSC 0)
);progn
(princ "\nNot A Block... Please Select Again: ")
);if
);progn
(princ "\nNothing Selected... Please Select Again: ")
);if
T-Square
« Reply #2 on: April 06, 2008, 05:48:00 PM »
Getting there...
(defun c:ONELINE (/ DIMSC BLK1 BLKENT BLK2)
(setvar "attreq" 0)
(while
(if BLK1
(setq INSPT(list (+ (car INSPT) (* DIMSC 0.75)) (- (cadr INSPT) 0.0)))
);progn
);if
);progn
);if
);while
T-Square
« Reply #3 on: April 06, 2008, 06:37:38 PM »
Works for me... Anyone care to critique... additions... subtractions?
"INITERR" & "RESET" are functions within my local error trap loaded at startup.
(INITERR)
(setvar "CMDECHO" 0)
(command ".undo" "end")
(command ".undo" "m")
(setvar "CECOLOR" "bylayer")
(setvar "CELTYPE" "bylayer")
(setvar "CELWEIGHT" -1)
(setvar "SNAPMODE" 0)
(setvar "ATTREQ" 0)
(graphscr)
(GETSPACE)
(MAKEONELINELAYER)
(while
(if BLK1
(RESET)
;;;;;;;;;;Sub Functions
(defun GETSPACE (/)
(if (and (equal (getvar "TILEMODE") 0)
(equal (getvar "CVPORT") 1)
(setq CSPACE 1);paper space
(setq CSPACE 0);model space.
(if (= CSPACE 1)
(setq DIMSC 1.0)
(setq DIMSC(getvar "DIMSCALE"))
(defun MAKEONELINELAYER (/)
(setq LAY "YOURLAYERHERE")
(if (not (tblsearch "layer" LAY))
(command ".-layer" "thaw" LAY "on" LAY "unlock" LAY "make" LAY "color" "1" LAY "lt" "continuous" LAY "")
(princ (strcat "\nLayer " LAY " Already Exists... Layer Un-Changed... "))
(setvar "clayer" LAY)
Couple of things I am not sure if I want to tackle. Not all of my blocks are inserted about the center of the block. Thus, some are slightly off the center of the one line. Oh, and I can't remember how to keep the loop going if "Nothing Selected... Please Select Again" comes up.
« Reply #4 on: April 07, 2008, 09:23:59 AM »
I made a few changes, not knowing exactly what you are trying to acheave.
          ; (INITERR) ; ???
                 ;| turned off during debug
  (setvar "ATTREQ" 0)
  (graphscr) |;
  (setq DIMSC (GETDIMSCALE)) ; CAB
  (MAKEONELINELAYER "YOURLAYERHERE") ; CAB
  (if (setq INSPT (getpoint "\nSelect One Line Start Point: "))
    (while
        ((null (setvar "ErrNo" 0))) ; reset var, cond never stops here
        ((and (setq BLK1 (entsel "\nSelect A Block: "))
              (setq BLKENT (entget (car BLK1)))
         (setq BLK2 (cdr (assoc 2 BLKENT)))
         (setq
           INSPT (list (+ (car INSPT) (* DIMSC 0.75)) (- (cadr INSPT) 0.0))
        ((= (getvar "errno") 52) (prompt "\nUser Quit.")) ; Exit on ENTER key
        (BLK1 (princ "\nNot A Block... Please Select Again: "))
        ((princ "\nNothing Selected... Please Select Again: "))
        ;; note that princ returns not nil
        ;;  using prompt will cause an exit from the loop
          ; (RESET) ; ???
(defun GETDIMSCALE () ; CAB revised
    1.0   ; paper space
    (getvar "DIMSCALE") ; model space.
(defun MAKEONELINELAYER (LAY /) ; let the calling routine supply the layer
  ;;  (setq LAY "YOURLAYERHERE")
      ;;(setvar "clayer" LAY)  <---<<  change this
      (command "._Layer" "_Thaw" LAY "_On" LAY "_UnLock" LAY "_Set" LAY "")
          ; to this
tfpacad19
« Reply #5 on: January 21, 2019, 04:38:24 PM »
CAB,
It has been a long time since I visited this one line topic.
Is there a way to modify the one line routine to utilize the "true" block name? I am using annotative/dynamic blocks now and the routine crashes when it encounters an anonymous block name.
I know this is a very old topic, I have started another job where I am utilizing this again.
Any help is appreciated.
tfpacad19
« Reply #6 on: February 13, 2019, 01:58:29 PM »
Hello all,
I have attached a dwg file showing a fire alarm block I have created. It is dynamic and annotative.
The problem I am having is how to pass the "actual" block name to the one line creation tool and not the anonymous block name.
I have included (3) different dwg versions for convenience.
Basically what I do is...
Convert room names from blocks/dtext/mtext to a combined mtext of the room name
Layout the devices
Create the one line by picking a start point and  then picking the block and it being added to the one line
Currently it does not select the room name, which would be a nice addition as I manually add this to the one line.
This would be a HUUUUUGE time saver for me.
If anyone can help me it would be greatly appreciated.
The attached code was created by CAB.
(INITERR)
(setvar "CMDECHO" 1)
(setvar "ATTREQ" 0)
(graphscr)
(GETSPACE)
(MAKEONELINELAYER)
(while
(if BLK1
(RESET)
(defun GETSPACE (/)
(if (= CSPACE 1)
(setq DIMSC 1.0)
(setq LAY "FA-ANNO-ONELINE")
Dlanor
« Reply #7 on: February 13, 2019, 05:17:53 PM »
Make these additions
This needs to go above/below/within the lisp file.
This gets the block name of any block
  1. (setq blk_name (vlax-get-property (vlax-ename->vla-object selected_entity) (if (vlax-property-available-p 'effectivename) 'effectivename 'name)))
selected_entity = (car (entsel)) so from your code (car BLK1).
Hope that all makes sense.
tfpacad19
« Reply #8 on: May 28, 2019, 06:05:15 PM »
Dlanor,
Thanks for the response and I apologize for the delayed reply.
Unfortunately I am, and always have been, a hack when it comes to coding. Consequently I do not know how to add the code to the routine. I understand the vl-load-com part.
Thanks for the assistance
