Author Topic: Global Attribute Editor  (Read 6267 times)
hendie
« on: April 03, 2008, 05:36:28 AM »
I haven’t posted anything of substance here for a while so I thought I’d share this…. I got bored yesterday and put this together
It’s a “Global” Attribute Editor which lists all blocks (containing attributes) in the current drawing.
When you select a block from the list, ( it also displays the layout) it displays the attributes associated with that block and from there you can modify the attribute value.
You can either
a) modify the attribute of only the selected block, or
b) modify ALL instances of that blocks attribute across all layouts
You also have the option to automatically switch to the selected blocks layout on selection and the option to zoom to the particular block you have selected
You can also apply a filter to list only blocks beginning with “abc” etc
You will need a Userform and the following controls :
Listboxes
Textboxes
Checkboxes
     Name: CBXgoto   caption: “Go To layout On Selection”
     Name: CBXzoom   caption: “Zoom To Block On Selection”    enabled: FALSE
     Name: CBXallLayouts   caption: “Apply To This Block On ALL Layouts”
Command Buttons
     Name: Cbfilter   caption: “Apply Filter”
     Name: CBclear   caption: “Clear Filter”
     Name: CBupdate   caption: “Update Block(s)”
     Name: CBexit      caption: “Exit”
Labels
     caption: “Attribute Value”
     caption: “Attribute List”
     caption: “Block .. (some spaces)… Layout”
     caption: “Show Only Blocks Beginning With…”
and a couple of Frames if you like to group the controls. I have 2 ~ one for “Block Filter” and one for “Block Details”
Next the code
Option Explicit
    Dim Block1Atts As Variant
    Dim Block1 As AcadBlockReference
Private Sub CBclear_Click()
' clear the filter and display all blocks with attributes
    LBblocks.Clear
    TBfilter.Text = ""
    Dim LO As AcadLayout
    Dim Ent As AcadEntity
    Dim Blk As AcadBlock
        For Each LO In ThisDrawing.Layouts
            For Each Ent In LO.Block
                If TypeOf Ent Is AcadBlockReference Then
                    Set Blk = ThisDrawing.ObjectIdToObject(Ent.OwnerID)
                    If Ent.HasAttributes = True Then
                        LBblocks.AddItem UCase(Ent.Name & vbTab & Blk.Layout.Name)
                    End If
                End If
            Next
        Next
' sort the listbox
    LBsort LBblocks
Private Sub CBexit_Click()
    Unload Me
Private Sub CBfilter_Click()
    LBblocks.Clear
' if the block name matches the filter text(with wildcard)
                    If Ent.Name Like UCase(TBfilter.Text) & "*" Then
                        End If
                    End If
                End If
            Next
        Next
    LBsort LBblocks
Private Sub CBupdate_Click()
    Dim BLKcoll As AcadSelectionSets
    Dim SSetBlks As AcadSelectionSet
    Dim NxtBlk As AcadBlockReference
    Dim BlkAtts As Variant
        Dim X As Integer
' if we are only updating the selected block then....
        If CBXallLayouts.Value = False Then
            For X = 0 To UBound(Block1Atts)
                If LBatts.Value = Block1Atts(X).TagString Then
                     Block1Atts(X).TextString = TBattValue.Text
                End If
            Next X
            Block1.Update
            Exit Sub
        Else
' or if we are updating this block across ALL layouts then...
' first check if any ss exist and if they do, delete them
            Set BLKcoll = ThisDrawing.SelectionSets
                For Each SSetBlks In BLKcoll
                    If SSetBlks.Name = "SSbks" Then
                        ThisDrawing.SelectionSets.Item("SSbks").Delete
                        Exit For
                    End If
                Next
' then get an SS of the blocks
            Set SSetBlks = ThisDrawing.SelectionSets.Add("SSbks")
                Dim FilterType(0 To 1) As Integer
                Dim FilterData(0 To 1) As Variant
                FilterType(0) = 0: FilterData(0) = "INSERT"
                FilterType(1) = 2: FilterData(1) = Block1.Name
            SSetBlks.Select acSelectionSetAll, , , FilterType, FilterData
' loop through the Sset, get attributes and apply the updated value to the attribute
            For Each NxtBlk In SSetBlks
                BlkAtts = NxtBlk.GetAttributes
                For X = 0 To UBound(BlkAtts)
                    If BlkAtts(X).TagString = LBatts.Value Then
                        BlkAtts(X).TextString = TBattValue.Text
                        NxtBlk.Update
                    End If
                Next X
            Next NxtBlk
        End If
' and clear the global checkbox
Private Sub CBXgoto_Click()
    If CBXgoto.Value = True Then
        CBXzoom.Enabled = True
    ElseIf CBXgoto.Value = False Then
        CBXzoom.Enabled = False
    End If
Private Sub LBatts_Click()
' dispay the attribute value when clicked
    Dim X As Integer
                TBattValue.Text = Block1Atts(X).TextString
            End If
        Next X
Private Sub LBblocks_Click()
TBattValue.Text = ""
    Dim BlockName As String
    Dim LayoutName As String
    Dim BlValue As Variant
' split the text into block name and layout name
        BlValue = LBblocks.Value
        BlValue = Split(BlValue, vbTab, , vbTextCompare)
        BlockName = BlValue(0)
        LayoutName = BlValue(1)
         Exit For
         End If
     Next
        FilterType(1) = 2: FilterData(1) = BlockName
' filter for the block on the current layout
    FilterLayout SSetBlks, LayoutName
' display the block tag string
    Dim i As Integer
        Set Block1 = SSetBlks.Item(0)
            'If Block1.HasAttributes = True Then
                LBatts.Clear
                Block1Atts = Block1.GetAttributes
                    For i = 0 To UBound(Block1Atts)
                        LBatts.AddItem Block1Atts(i).TagString
                    Next i
            'End If
' if "Go to layout on selection" is checked then
            ThisDrawing.ActiveLayout = ThisDrawing.Layouts(LayoutName)
' if "Zoom to block on selection" is checked then get the bounding box of the block
                If CBXzoom.Value = True Then
                    Dim BboxSP As Variant
                    Dim BboxEP As Variant
                        Block1.GetBoundingBox BboxSP, BboxEP
' and use the bounding box for a zoom window
                    Dim BboxP1(0 To 2) As Double
                    Dim BboxP2(0 To 2) As Double
                        BboxP1(0) = BboxSP(0): BboxP1(1) = BboxSP(1): BboxP1(2) = BboxSP(2)
                        BboxP2(0) = BboxEP(0): BboxP2(1) = BboxEP(1): BboxP2(2) = BboxEP(2)
                        ZoomWindow BboxP1, BboxP2
                End If
        End If
Private Sub UserForm_Initialize()
' find all blocks in drawing and if they have attributes
' then add them to the listbox
                    End If
                End If
            Next
        Next
' and sort the listbox
    LBsort LBblocks
Private Function LBsort(LB As ListBox)
' Sort the listbox
    Dim LBvar As Variant
    Dim i As Integer
    For i = 0 To LB.ListCount - 2
        If LB.List(i) > LB.List(i + 1) Then
            LBvar = LB.List(i)
            LB.List(i) = LB.List(i + 1)
            LB.List(i + 1) = LBvar
            i = -1
        End If
    Next i
End Function
Private Sub FilterLayout(SS As AcadSelectionSet, LOname As String)
' from code on Autodesk.com by Frank Oquendo
    Dim X As Integer
    Dim ObjArray() As AcadEntity
    Dim Max As Long
        Max = -1
    For X = 0 To SS.Count - 1
        If LCase(ThisDrawing.ObjectIdToObject(SS.Item(X).OwnerID).Layout.Name) <> LCase(LOname) Then
            Max = Max + 1
            ReDim Preserve ObjArray(0 To Max)
            Set ObjArray(Max) = SS.Item(X)
        End If
    Next X
    SS.RemoveItems ObjArray
not fully tested so use at your own risk yada yada yada
comments, suggestions welcomed
oh, and if you're lazy, here's the file......
quamper
Re: Global Attribute Editor
« Reply #1 on: April 03, 2008, 08:06:40 AM »
Thats great! Thanks
The gatte command is one of my favorite express tools. Nice to have a much improved gui version of it!
Guest
« Reply #2 on: April 03, 2008, 08:23:37 AM »
Looks pretty cool.  Snagged myself a copy.
I like the listbox sort function.  I've got a few proggies where that will come in handy, Hendie.
*hehehehe... handy, Hendie*
astro86
« Reply #3 on: August 10, 2009, 09:01:23 AM »
i would like to download the code to test it but it's not working...  :|
can somebody send me the zip file please?
Thank you in advance
ArgV
« Reply #4 on: August 14, 2009, 08:14:33 PM »
You can either
Listboxes
Textboxes
Checkboxes
Command Buttons
Labels
Next the code
Option Explicit
    LBblocks.Clear
    TBfilter.Text = ""
                    End If
                End If
            Next
        Next
' sort the listbox
    LBsort LBblocks
    Unload Me
    LBblocks.Clear
                        End If
                    End If
                End If
            Next
        Next
    LBsort LBblocks
        Dim X As Integer
                End If
            Next X
            Block1.Update
            Exit Sub
        Else
                        Exit For
                    End If
                Next
                        NxtBlk.Update
                    End If
                Next X
            Next NxtBlk
        End If
    End If
    Dim X As Integer
            End If
        Next X
         Exit For
         End If
     Next
    Dim i As Integer
                LBatts.Clear
                    Next i
            'End If
                End If
        End If
                    End If
                End If
            Next
        Next
    LBsort LBblocks
' Sort the listbox
    Dim i As Integer
            LBvar = LB.List(i)
            i = -1
        End If
    Next i
End Function
    Dim X As Integer
    Dim Max As Long
        Max = -1
            Max = Max + 1
        End If
    Next X
I'm lazy, but I've never really used VB before. How do you run this file please? thanks!
-ArgV
HasanCAD
« Reply #5 on: January 11, 2010, 05:09:22 AM »
How to run this VBA
fixo
« Reply #6 on: January 12, 2010, 12:19:49 AM »
How to run this VBA
Unzip project
Open AutoCAD
Type VBAMAN in the command line then dialog window will be appears
Select and load this project
Type VBARUN
Select you need to run
~'J'~
CottageCGirl
« Reply #7 on: January 12, 2010, 09:58:44 AM »
nice Hendie....not time to play now, but hopefully soon.
HasanCAD
« Reply #8 on: January 26, 2010, 03:21:01 AM »
How to run this VBA
Unzip project
Open AutoCAD
Type VBARUN
~'J'~
I did but no thing in VBARUN dialog Window
After seaching, He didnot add this line
Userform.Show
Am I right?
Second
this VBA not dealing with Dynamic Blocks even which have an attribute.
