Your select all code works fine, the way it should do, but not when i have that listbox_change event that loads the array aswell - when that code is in place, the select all code only selects the first item in the listbox, not all entries..
All i want is to have a checkbox that the user can check to select all the layouts (the listbox items) or uncheck to deselect them all..
But......i also need that code you posted for loading all the layoutnames from what has been selected in the listbox into a string array, built into the listbox_change event, so i can loop through them when it comes to performing the main structure of the program..
but the listbox_change event seems to be conflicting with the checkbox_click event and i don't see why, or indeed how to get round it..
