Author Topic: How Can this Routine be Consolidated?  (Read 2498 times)
« on: August 24, 2004, 01:29:03 PM »
It allows you to select a block to define layer to trim around. Then it cycles through all the blocks on that layer and trims polyline that cross through them. Can it be edited so it will run faster?
;;;| SYMT                                                   |
;;;| Trim polylines so that they will not cross symbols.    |
;;;| A union between a set of layers and a set of symbols   |
;;;| will be trimed.                                        |
(defun C:SYMT     (
                  S              ; selection set of entities
                  LS             ; selection set of layer entities
                  en             ; specific entity from selection set
                  ed             ; data associated with specific entity
                  len            ; specific layer entity from selection set
                  led            ; data associated with specific layer entity
                  count          ; selection set counter
                  lcount         ; layer selection set counter
   (setvar "CMDECHO" 0)                     ;0 to hide command echos
   (pusherr (list (list setq 'S nil 'LS nil)))
   (pushvar '("SNAPMODE" "OSMODE"))
   (setvar "OSMODE" 0)                      ;Clear object snap mode
   (setvar "SNAPMODE" 0)
   (setq
      S (ssadd)
      LS (ssadd)
      count 0
   (lfeed 3)
   (prompt "\nIdentify the layer(s) containing symbols to trim around:")
   (setq LS (ssget))                        ; Get entities marked by user
   (lfeed 3)
   (prompt "\nSelect set containing symbols to be trimed around:")
   (setq S (ssget))                         ; Get entities marked by user
   (lfeed 3)
   (if S (progn                             ; if set exists
      (repeat (sslength S)                  ; traverse selection set
         (setq
            en (ssname S count)
            ed (entget en)
            count (1+ count)
            lcount 0
         (if (= "INSERT" (dxf 0 ed))(progn  ; if insertion block
            (repeat (sslength LS)
               (setq
                  len (ssname LS lcount)
                  led (entget len)
                  lcount (1+ lcount)
               (if (= (dxf 8 ed) (dxf 8 led)) (symtr ed))
            ); end repeat
         ));end if
      ); end while
   ));end if
);defun
(if debug (princ "c:symt loaded\n"))
(C:SYMT)
;;;| SYMTR                                                  |
;;;| Trim the polylines crossing the specified symbol.      |
(defun symtr      (
                  spnt           ; entity data associated with trim symbol
                  cutent         ; entity used as cutting edge in trim
                  r              ; radius of symbol
                  pt1            ; insertion point of symbol
   (pusherr (list (list setq 'S nil)))
   (setq
      pt1 (dxf 10 spnt)
      r (/ (abs (dxf 41 spnt)) 2)
   (command "_.CIRCLE" pt1 r)
   (setq
      cutent (entlast)
      S (ssget "_F" (cltolist cutent 20))
      count 0
      (command "_.TRIM" cutent "")
         (setq
            en (ssname S count)
            ed (entget en)
            count (1+ count)
         (if (/= "INSERT" (dxf 0 ed))       ; if not insertion block
            (command (list en pt1))
      ); end while
      (command "")
   ));end if
   (command "_.ERASE" cutent "")
);defun
(if debug (princ "symtr loaded\n"))
;;;| PUSHERR                                                |
;;;| Push a sublist of error expressions onto the #error    |
;;;| list.                                                  |
(defun pusherr    (
                  sublst         ; sublist to be pushed onto the list
                ; #error         ; list of commands to execute on error
   (setq #error (append sublst #error))   ;add sublst to the list
);defun
(if debug (princ "pusherr loaded\n"))
;;;| PUSHVAR                                                |
;;;| Push system variables onto the #error list.            |
(defun pushvar    (
                  varlst         ; list of variables to be added to #error list
   (repeat (length varlst)                  ;for all vars in varlst
      (setq
         #error (append (list (list setvar (car varlst) (getvar (car varlst)))) #error)
         varlst (cdr varlst)
);defun
(if debug (princ "pushvar loaded\n"))
;;;| LFEED                                                  |
;;;| Prints the number of line feeds passed to it.          |
(defun lfeed      (
                  count          ; number of line feeds to print
   (repeat (1- count) (princ "\n "))
   (princ "\n")
); defun
(if debug (princ "lfeed loaded\n"))
;;;| DXF                                                    |
;;;| Takes an integer dxf code and an entity or entity data |
;;;| list and returns the data element of the association   |
;;;| pair.                                                  |
(defun dxf        (
                  code           ; DXF code
                  ed             ; Entity name or data list
                                             ; Turn entity name into entity data
  (if (and (not (listp ed)) ed) (setq ed (entget ed)))
  (cdr (assoc code ed))                      ; Find association pair & strip 1st element
); defun
(if debug (princ "dxf loaded\n"))
;;; CLTOLIST                                                |
;;; This function will convert a circle to a list of        |
;;; points.  The circle is subdivided into the specified    |
;;; number of segments.                                     |
(defun cltolist   (
                  en              ; Entity name to convert
                  segs            ; Number of segments
                  ed              ; Current entity data
                  plist           ; Point list to be returned
                  rad             ; Radius of arc
                  cp              ; Center point of arc
                  ang1            ; Initial angle
                  angs            ; Angle between subsegments in arc
                  count           ; Counter of arc subsegments
  (if (= (dxf 0 en) "CIRCLE") (progn
                                             ; Traverse the pline
    (setq
      ed (entget en)
      plist nil
                                             ; Define the circle
      cp (dxf 10 ed)
      rad (dxf 40 ed)
      ang1 0
                                             ; Prepare to traverse the arc
      angs (/ (* PI 2) segs)
      count 0
                                             ; Traverse the arc & save points
    (while (< count segs)
      (setq
        plist (append plist (list (polar cp (+ ang1 (* count angs)) rad)))
        count (1+ count)
    );end while
                                             ; Close the polyline
    (setq plist (append plist (list (car plist))))
  ));end if
                                             ; Return the point list
  (if plist plist nil)
);defun
(if debug (princ "cltolist loaded\n"))
« Reply #1 on: August 24, 2004, 01:31:23 PM »
I dont understand? Consolidated into what?
« Reply #2 on: August 24, 2004, 01:33:08 PM »
Bad choice of words on my part.....was wondering if the routine could be made faster.
daron
« Reply #3 on: August 24, 2004, 01:36:04 PM »
It looks pretty clean up until you see all the command code that could be changed to something like entmake, but I don't think anything will really make it much faster. Milliseconds maybe, unless you're talking hundreds of object insertions. You do recall the code races we had in the early days of the swamp, I presume. Search them out. They're in vlisp hackers. Mark, Stig and myself were quite involved in testing different functions with the help of others.
« Reply #4 on: August 24, 2004, 01:36:24 PM »
Oh, I get cha.
...I Duno. We would have to break the app down piece by piece and "evaluate" each process. (Basicly, speed of code is a concern that should be addressed right away.)
