Author Topic: Automation Error. No database  (Read 8547 times)
DEVITG
« on: August 24, 2004, 12:56:27 PM »
(setq e-ENTITY (car (entsel "\nPick ENTY:")))
 (SETQ EG-ETY (ENTGET e-ENTITY))
(setq vla-ENTITY (vlax-ename->vla-object e-ENTITY))
This give me this error
What it's happen???? :oops:
« Reply #1 on: August 24, 2004, 01:04:09 PM »
what are you selecting in the dwg?
« Reply #2 on: August 24, 2004, 01:06:11 PM »
<guess>Selecting a custom object, like an Autoplant component?</guess>
DEVITG
« Reply #3 on: August 24, 2004, 01:12:11 PM »
a line , or a cube 3dsolid.
as follow
((-1 . <Entity name: 40062d78>) (0 . "3DSOLID") (330 . <Entity name: 40062cf8>) (
« Reply #4 on: August 24, 2004, 01:20:17 PM »
Beats me! Using your code I get the following.
((-1 . <Entity name: 7ef60e18>) (0 . "3DSOLID")
#<VLA-OBJECT IAcad3DSolid 08c48eb4>
DEVITG
here is the dwg I use
« Reply #5 on: August 24, 2004, 01:26:41 PM »
It is the dwg
http://theswamp.org/lilly.pond/devitg/cube%20line.dwg
it is the code
(defun c:v-p ()
(setq vla-ENTITY (vlax-ename->vla-object e-ENTITY ))
);_end defun
(c:v-p)
daron
« Reply #6 on: August 24, 2004, 01:27:14 PM »
It's possible, you missed or are in a paperspace layout and not mspacing through, therefore selecting nothing. If you were to set up a trap i.e.
(while (not (setq ent (car (entget "\nblah blah:"))))
(princ "\nYou missed.")
you shouldn't get an automation error.
« Reply #7 on: August 24, 2004, 01:33:58 PM »
(defun c:vp ( / ename )
    (if (setq ename (car (entsel)))
        (vlax-ename->vla-object ename)
« Reply #8 on: August 24, 2004, 01:35:11 PM »
I have no problems with the dwg either.
DEVITG
« Reply #9 on: August 24, 2004, 01:38:41 PM »
the   e-ENTITY is selected
I work on model space  as follow
the problem when I do
Seem to be some related whit VL
It is a new instalation , maybe I lost some to include on it.
DEVITG
seem to be a vl fault
« Reply #10 on: August 24, 2004, 08:19:57 PM »
all my lisp with a vl,  fault , what could be lost .
The vl.arx is loadaed
Help me please
 As I told , it is a new ACAD instalation after a hard disk change.
 :cry:  :oops:  :cry:  :oops:  :cry:
« Reply #11 on: August 24, 2004, 11:37:57 PM »
I don't think that error is caused by this, but it can't hurt to try..... type (vl-load-com) before running your routine. If that solves it, add (vl-load-com) to your acad.lsp file
Good luck!
DEVITG
« Reply #12 on: August 25, 2004, 08:04:12 AM »
please see my code , it has the (vl-load-com)
So, that is not the fault.
daron
« Reply #13 on: August 25, 2004, 09:05:26 AM »
If it's a new install, try running a repair in the add/remove under control panel. Might fix the problem.
DEVITG
« Reply #14 on: August 25, 2004, 07:16:00 PM »
I did 3 times the install , the error persist.
HELP ME PLEASE
