Author Topic: Autocad Quad Map s to DWG  (Read 5567 times)
MSTG007
« on: August 24, 2004, 08:52:00 AM »
I have access to tiff files of a whole state. I want to know what would be the ideal format to change the tiffs to so i can place them in a dwg by using the image manager.
That way i can xref the quad map into dwgs i need location maps for and other uses. to get info.
Civil3D 2020
« Reply #1 on: August 24, 2004, 09:11:15 AM »
These .tif images are scans of the original quad maps? Or are you talking aerials.
MSTG007
« Reply #2 on: August 24, 2004, 09:12:21 AM »
i am talking quad maps... no aerials... aerials are huge and are in a SID format. but if i can get the quads to SPCS, id be good
Civil3D 2020
« Reply #3 on: August 24, 2004, 09:20:40 AM »
I'm doing something similar rigth now only I'm using FEMA maps. My procedure;
1: open new dwg
2: query section lines streets and other topo features for existing dwgs
3: insert image near line work with generic scale.
4: select two points on both the image and the line work which represent  the same place geographically.
5: move scale and rotate the image to match line work.
6: discard line work save the dwg.
the image is now positioned realitive to SP in that dwg.
later I'll created a new image that is georeferenced.
MSTG007
« Reply #4 on: August 24, 2004, 09:54:34 AM »
here is what i am thinking of.... there are several quads....
have one drawing or 3 dwgs... north, mid, south dwgs...
imagemanager for the quads in the desinate place... save
and be done...
but i am not sure about data base using map
Civil3D 2020
« Reply #5 on: August 24, 2004, 10:31:28 AM »
how are you going to relate them to SP?
MSTG007
« Reply #6 on: August 24, 2004, 03:28:14 PM »
i am lost on SP. what do you mean
Civil3D 2020
« Reply #7 on: August 24, 2004, 03:40:44 PM »
Sorry, state plane coordinates.
