Author Topic: CAN I DISABLE THE EXPLODE COMMAND??  (Read 9748 times)
STEVEDALLAS
« on: March 26, 2008, 01:01:40 PM »
I hate the explode command!
Yes, sometimes it is needed.
I always get cad operators using it at the "drop of a hat". AARRRGGGHHH!
I can see using "xplode", so id "explode" is used an alert pops up.
any ideas?
deegeecees
Re: CAN I DISABLE THE EXPLODE COMMAND??
« Reply #1 on: March 26, 2008, 01:03:45 PM »
undefine
STEVEDALLAS
« Reply #2 on: March 26, 2008, 01:45:29 PM »
thank you
KewlToyZ
« Reply #3 on: March 26, 2008, 01:47:49 PM »
placing it into the enterprise mnl file?
STEVEDALLAS
« Reply #4 on: March 26, 2008, 01:56:26 PM »
That's what i'm doing.
ELOQUINTET
« Reply #5 on: March 26, 2008, 05:20:56 PM »
create your blocks and put them into a palette and set it to not allow exploding?
have them stay after work until they finish writing do not explode blocks 300 times on a piece of paper!!!
CADaver
« Reply #6 on: March 26, 2008, 11:00:00 PM »
I once redefined the explode command to save the file to a different location, erase everything, save it over the old file and exit.  Every time they tried to explode something, it killed AutoCAD and emptied their drawing.
Bob Wahr
« Reply #7 on: March 26, 2008, 11:02:56 PM »
I explode stuff daily.
uncoolperson
« Reply #8 on: March 26, 2008, 11:41:43 PM »
my explode command (actually the drafters i work with, because of me) draws a grdraw explosion as a reminder that explode is bad.
Bethrine
« Reply #9 on: March 27, 2008, 12:45:04 AM »
 :lmao: :lmao: :lmao: You would've done me in months ago!
Ahem, <mouse-like in the corner and vewy, vewy quietly..."why is explode bad?" I use it a lot and never have a problem. I redefine blocks all the time too. <raises force field quickly>
Josh Nieman
« Reply #10 on: March 27, 2008, 08:59:52 AM »
I use explode all the danged time.
It's just a tool.
Bob Wahr
« Reply #11 on: March 27, 2008, 11:46:48 AM »
Explode used when it shouldn't be is a bad thing.  I'm a big boy, I know when I need to explode something, and why.  Programming to force good behavior on bad drafters is a bad thing.  Teaching them to do things correctly and explaining to them why it's the correct way is a lot better.  You don't have to dummy proof your system if you do your best to ensure that the people manipulating your drawings aren't dummies.
Josh Nieman
« Reply #12 on: March 27, 2008, 11:51:07 AM »
I think Bob wins this thread.
The guys here exploded stuff freely before I got here.  I'd seen of many ways to prevent this the hard way... I find that's childish, immature, and disrespectful to my coworkers.  I have more respect for their ability to learn than that.  I'd rather explain scenarios and the effects they may not have encountered or forseen yet.
By remapping their explode command, you end up with mindless drones who only know not to hit the button because of some weird voodoo magic, and thus haven't learned a thing, or worse, find a way to work around it and do it anyways without you knowing... by teaching my users the purpose why explode can be dangerous, they now are knowledgeable enough to use the tool properly, and eliminate the danger, while still ensuring their documents are as intelligent, associative, reliable, or reusable as ever despite them needing to explode something from time to time.
ELOQUINTET
« Reply #13 on: March 27, 2008, 11:53:51 AM »
i agree with bob you shouldn't have to disable any command but rather you should train people and if they do not follow your rules then fire them. i don't know what the job market is like outside of nyc but here decent drafters are a dime a dozen so finding a replacement for a jackass is not a huge deal. finding a senior draftsman can be difficult but someone just to do basic stuff, no.
Josh Nieman
« Reply #14 on: March 27, 2008, 11:55:45 AM »
Definitely not what it's like around here!  We can't find -any- drafters.  Of course the boss's aren't as pro-active about the search as I wish they'd be, or as they need to be, with engineers OR drafters, but they're just aren't too much to be spoken of, around here, compared to the jobs available.
« Reply #15 on: March 27, 2008, 12:12:18 PM »
I agree that a properly trained person can be a valuable resource and would preclude the need to force compliance by code, however, I have been on both ends of this issue. Once with a company that had such tight controls that the drawing process was mundane and unimaginative, and once where it didn't matter what the drawing was like in the computer, just as long as the final product looked ok.
In the first instance, automation was a breeze because even the novice could draw correctly, however, in the latter, automation was a nightmare because nothing was consistant.
There must be a happy medium ... and if forcing folks to use one command over another is the means to an end, then I am not the one to say otherwise.
deegeecees
« Reply #16 on: March 27, 2008, 12:15:07 PM »
When I was acting as Cad Manager for a well known power company, it was in my best interest to programatcally guide the grunt drafters as much as possible, only because of the revolving door contract employee rate. The hiring process was very lax, and thus I had minimal experienced red-line picker uppers to work with. The mindset there was basically, learn AutoCad on your own time, and do what only needs to be done. Having all standards enforced through Lisp/VBA etc. was needed. 30-40 drafters with the ability to destroy a drawings integrity by exploding a block with attributes would have been a nightmare. Just another situation where that shoe fit all too well.
Bob Wahr
« Reply #17 on: March 27, 2008, 12:24:42 PM »
Deeg, in that case, I can see blocking the explosion of blocks with attributes and some standards enforcement though code.
We have a fairly comprehensive CAD Standard with reasonable documentation.  We are working on improving the documentation.  As long as the drawings are correct, done to standard, and done in a timely fashion, I don't care what commands they use to get there.  Then again, if I worked somewhere that had undefined commands, i could always use the menstrual version.
deegeecees
« Reply #18 on: March 27, 2008, 12:45:05 PM »
I've worked for some major companies, such as GMEMD (think locomotives), and have seen Cad Standard books as thick as encyclopedias (given their platform was Unigraphics), that were adhered to as much as humanly possible.
A million ways to skin a cat in AC, that's open architecture for ya!
CADaver
« Reply #19 on: March 27, 2008, 06:19:41 PM »
It's just a tool.
So is ERASE, but erasing important stuff or the wrong stuff can be counter-productive, can it not?  But for us, there is never a need to explode anything, any time.  We build a lot of intelligence into a model that can get buggered up with an EXPLODE, not so much now.  Most have been trained and use the proper tools to get what they need, but every now and then we get some cad "expert" that doesn't need to use the tools we have in place to manage our spec-data-material-models.  Then he's confused when his iso bill won't fill in or his requisition codes won't export.
CADaver
« Reply #20 on: March 27, 2008, 06:27:58 PM »
Around here, drawings have become only a small part of our deliverable and many of those are created automatically from the intelligence residing in the model.  In addition to the drawings we also produce cut bills, spec-driven material lists, material requisitions, purchase orders, delivery points, warehousing/stockpiling data, and schedules for all the above plus schedules for fabrication, erection and testing.  Throwing an odd EXPLODE command in the middle of all that can have unpleasant results.  But that's here.
Bob Wahr
« Reply #21 on: March 27, 2008, 06:37:27 PM »
It's just a tool.
And yet, erasing things that need to be erased works swell.  I never said that I advocate exploding everything in the drawing any more than erasing everything in the drawing, moving everything in the drawing, or any of a large number of other commands.  I still say that it's better to educate the users on the proper way to draft in your system.
By drawing, I mean electronic, not paper.  If an element with intelligence is exploded the the drawing is not correct.
« Reply #22 on: March 27, 2008, 06:48:47 PM »
(command "redefine" "explode" "superflatten") :-D
CADaver
« Reply #23 on: March 27, 2008, 07:28:45 PM »
Oh, so do I, however, we've run into some that just don't/won't/can't "get it", and we need to protect ourselves as much as practical from an errant user.  It is much better never to have an automobile accident, but I still wear a seatbelt.
Unfortunately we won't know until time to extract that intelligence because the "drawing" "looks" correct.  A lot of pipe can be placed in the mean time.
Josh Nieman
« Reply #24 on: March 28, 2008, 09:11:16 AM »
Then those "can't wont' don't" folks should be properly trained, properly reprimanded, or properly dealt with, if need be.
CADaver
« Reply #25 on: March 28, 2008, 06:22:55 PM »
No doubt, but major damage can be wrought between training and "You did WHAT!?!?!?"
« Reply #26 on: March 29, 2008, 08:34:11 AM »
How about redefining the Explode command so that it writes to a log file, the user name and the object exploded.
If it is a block then include the insert point in the log. The CAD manager could then run a Check routine that would look at all the log files and alert them if any blocks were exploded.
Then that CAD operator could be scheduled for more training.  :-)
« Reply #27 on: March 29, 2008, 10:11:37 AM »
Schneeky...I like it! :)
KewlToyZ
« Reply #28 on: April 01, 2008, 10:42:22 AM »
:lmao:
(command "redefine" "explode" "speak")
(DEFUN c:speak ()
  (setq speak (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke speak "Speak" "Would you like to clean out your desk now or shall I do it for you?" 0)
  (vlax-release-object speak)
deegeecees
« Reply #29 on: April 01, 2008, 10:46:45 AM »
WOW! That IS kewl! I never looked into Sapi before, thanks!!!!
Zydenet
« Reply #30 on: April 01, 2008, 12:55:20 PM »
LMAO, very nice KewlToyZ. How about combining it with a reactor so they can't get around it.
(or explodereactor
    (setq explodereactor
           (vlr-command-reactor
             nil
             '((:vlr-commandwillstart . cmdstart)
               (:vlr-commandended . cmdend)
               (:vlr-commandcancelled . cmdcan)
             ) ;_ end of vlr-command-reactor
          ) ;_ end of setq
    ) ;_ end of or
(defun cmdstart (react cmd /)
  (setq cmd (strcase (car cmd) t))
    ((wcmatch cmd "*explode*")
     (vlax-invoke speak "Speak" "I will drag you over hot coals if you do what I think you're about to do" 0)
  ) ;_ end of defun
(defun cmdend (react cmd /)
     (vlax-invoke speak "Speak" "If you exploded any dimensions, m text or peelines, you are gone" 0)
  ) ;_ end of defun
(defun cmdcan (react cmd /)
     (vlax-invoke speak "Speak" "Smart move, canceling out" 0)
  ) ;_ end of defun
deegeecees
« Reply #31 on: April 01, 2008, 12:57:35 PM »
Thats a keeper!
Josh Nieman
« Reply #32 on: April 01, 2008, 01:07:43 PM »
hahaha I like it.
Zydenet
« Reply #33 on: April 01, 2008, 03:20:13 PM »
I wish I had someone here doing cad to mess with. It's not as funny when I burn myself.
"peelines" I guess I could of used "p lines".
KewlToyZ
« Reply #34 on: April 01, 2008, 05:56:14 PM »
LOL, well if you were up north I would venture a yellow snow reference  :kewl:
« Reply #35 on: April 01, 2008, 06:50:24 PM »
This a funny development.  I think the user should be prompted to turn in their resignation. Informed that their severance package will be delivered to them shortly.
« Reply #36 on: April 01, 2008, 11:08:40 PM »
Bethrine
« Reply #37 on: April 04, 2008, 01:32:02 AM »
Hmm. I try not to explode anything and if I do I redefine the block if it is applicable to all the blocks used in that drawing. However, fairly often I find one particular piece that needs a dashed line of a different lineweight in the same block so I will explode it and use that one in paticular for that instance. If there is a better way I am all ears! Ah...eyes ;)
