Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
Vertically Challenged
Land Lubber / Geographically Positioned
Topic:
C3D 2008 - Change AECC_CONTOUR Display?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: C3D 2008 - Change AECC_CONTOUR Display? (Read 1564 times)
FengK
Guest
on:
March 24, 2008, 03:39:53 PM »
Hello,
In C3D 2008, is there a way to change the display of AECC_CONTOUR objects? For example, the elevation label size? I saw C3D has an utility to convert Land Desktop points, but didn't see one to convert AECC_CONTOUR objects.
Thanks.
Logged
Seagull
Every Student their own Lesson
WWW
Re: C3D 2008 - Change AECC_CONTOUR Display?
Reply #1 on:
March 24, 2008, 03:45:45 PM »
No Kelie,
The 'programmers' decided to name the command Add Contour Data, to the surface definition only the joke is one can NOT use contour objects. One MUST explode them into polylines and THEN one can add them as contour data. Just the opposite of Land wherein one had to convert polylines into contour objects. Now one must convert ones contours into polylines.
OR the better option would be to place a copy of the original TIN in the C3D project folder and create your surface from that TIN file. Given that one already has the surface or one wouldn't have AEC contour Objects.
Logged
FengK
Guest
Reply #2 on:
March 24, 2008, 03:59:18 PM »
Thanks Michael.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
Topic:
