Author Topic: QSAVE  (Read 3286 times)
cadpro
QSAVE
« on: March 12, 2008, 07:49:56 AM »
Hi all,
Is it possible to run a command and then save the dwg when the user hits QSAVE in .NET?
Re: QSAVE
« Reply #1 on: March 12, 2008, 10:57:22 AM »
I think you would have to use events, or you could create your own command, and have that button execute you command which will do something and then save the current document.
cadpro
Re: QSAVE
« Reply #2 on: March 13, 2008, 01:38:49 AM »
I want to reset the scalelist and then save the dwg when the user hits the save button. Is it possible to redefine the QSAVE command?
Re: QSAVE
« Reply #3 on: March 13, 2008, 04:15:27 AM »
Why do you want to redefine the QSAVE command. ?
Don't you want to just save the drawing as part of the routine which resets the ScaleList ??
cadpro
Re: QSAVE
« Reply #4 on: March 13, 2008, 07:11:38 AM »
That would also be fine. But it should happen when the user hits QSAVE.
mcarson
Re: QSAVE
« Reply #5 on: March 24, 2008, 12:33:53 PM »
Not really worked with AutoCAD events in .NET, but with VBA I used the BeforeSave or OnSave event of the active document/
Using this, you could add your code to reset your scale list and optionally (I think) continue with the save, or cancel it!
