Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
Vertically Challenged
Land Lubber / Geographically Positioned
Topic:
utm
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: utm (Read 3607 times)
drizzt
Guest
utm
on:
August 23, 2004, 05:01:12 PM »
I recieved a file from a surveyor that is on the wrong utm. I need to insert another file at the correct utm. What is the easiest, fasted way to correct the incorrect utm?
Logged
Custom Title
Seagull
utm
Reply #1 on:
August 24, 2004, 05:34:39 PM »
Make sure both files have the coord system defined and use map to query all the objects from the dwg you want to change. that will convert the coord system for you.
Logged
TheSwamp.org (
serving the CAD community since 2003
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
Topic:
utm
