Author Topic: I want/need a program  (Read 9767 times)
« on: September 26, 2003, 09:27:52 AM »
It needs to do this:
prompt user for 2 points;
draw line between points
start extend command
use line to extend too
prompt user for "Select object to extend"
all I'm going to extend is a line nothing fancy.
« Reply #1 on: September 26, 2003, 09:49:10 AM »
Like this?
(defun mst-extend ()
  (vl-cmdf "line" (getpoint (setq x (getpoint))) x "")
  (vl-cmdf "extend" (entsel))
« Reply #2 on: September 26, 2003, 09:55:12 AM »
close.
but I don't want to have to select the line i just created, just the line to extend.
« Reply #3 on: September 26, 2003, 10:28:13 AM »
Like this?
(defun mst-extend2 ()
  (setq line (vla-addline
               (vla-get-ModelSpace
                 (vla-get-ActiveDocument
                   (vlax-get-object "AutoCAD.Application")))
               (vlax-3d-point (getpoint (setq x (getpoint))))
               (vlax-3d-point x)))
  (vl-cmdf "extend" (vlax-vla-object->ename line))
  (if (not (vlax-object-released-p line))
    (vlax-release-object line)
BTW, My "junk" file is getting WAY to big. (I couldnt find anything i was looking for. :P )
EDIT: Released the line object.
« Reply #4 on: September 26, 2003, 10:37:33 AM »
Almost!! but close enough. :D
mine, based on yours.
(defun mst-extend2 (/ line)
      (vla-get-ModelSpace
      (vlax-3d-point
(getpoint "\nSelect 2nd Point: "
  (setq x (getpoint "\nSelect 1st Point: "))
      (vlax-3d-point x)
  (if line
    (progn (vl-cmdf "extend" (vlax-vla-object->ename line) "")
notice the "" in the cmdf statement.
« Reply #5 on: September 26, 2003, 10:45:23 AM »
dosent work.  :?
Wait, you wanted to extend the line you just drew? (that doesnet make anysense!) Ohhh i get what your after ...i think. You want to extend aother line to this line you just drew. (Now that would change things a bit.)  Sorry, i misunderstood ya.
Glad it works.
« Reply #6 on: September 26, 2003, 10:52:17 AM »
Glad it works
me too!!
