read an efbp or CAiCE .xyz file and convert it to a .csv file
you have two options for the .csv file
1. with point numbers (the program reads the point name
from the .xyz file i.e. GND234 and uses the 234 for the
point number in the .csv file) format = PNEZRD (point number
,northing,easting,elevation,raw desc.,full desc.) raw desc.
= point name, i.e. GND234 and full desc. = G 99 code from
the .xyz file.
2. the same as 1 without the point number. format = NEZRD
http://www.theswamp.org/swamp.files/Public/xyz2csv.zip
