Author Topic: 2008 odd behavior  (Read 3704 times)
Bob Wahr
Re: 2008 odd behavior
« Reply #15 on: March 24, 2008, 02:56:25 PM »
Had it happen to me this morning so I did some screenshots.
Image3.jpg is the 'xref has been modified, blah blah,' balloon notification.
Image4.jpg is the open file dialog.  A very common alternative to this one is that all file dialogs have "Save Drawing As %S", regardless of whether you are saving, opening, saving as(save asing?).
« Reply #16 on: March 25, 2008, 08:23:58 AM »
I got nothing ....
craigr
« Reply #17 on: March 26, 2008, 11:24:07 AM »
This issue is likely caused by a memory issue.
I had this problem on several workstations and increasing the memory finally resolved the issue
While reading the first posts to Keith's, I was leaning towards it being a memory problem also. I have also seen where a workstation has enough memory, but one of the chips has a problem with it. I switched the RAM with another of the same size and all worked well. So, I replaced the original RAM to rule out the RAM not being seated well and the problem re-appeared, thus Bad RAM.
CAD seems to use memory differently than other programs. The machine I am talking about ran all of its other programs fine.
Just something to think about,
craigr
« Reply #18 on: March 26, 2008, 11:39:18 AM »
How much RAM is in this box? How large is your swap file? And your video card is?
