Hey Matt
I downloaded the file but I have not yet had a chance to look at it.
I will definitely look at it tomorrow...thank you
CM,
If you create a drawing called Plotconfigs, you can set up all your pagesetups in that drawing, then in your current drawing (in Paper space) type psetupin,
that will prompt you for a drawing, select your Plotconfigs drawing (or template .dwt) and it will expose all of your pagesetups in that drawing. You can also right click on your layout tab and use The Pagesetup Manager as well to achieve this. Command line is psetupin.
I can give you several reasons why you would do this.
Do you want to set up a plot configuration in every single drawing, or would you rather have one created and import it when needed? In some of my customizations, I will do -layout;
That will give you your options, then you can insert a layout from your Plotconfigs drawing (or .dwt), followed by Psetupin which will allow you to bring in your Plot config as well.
If you do this; you will have all of your plotter configs setup in advance.
So, for instance, say you want to create a new layout; bring in the layout, then the pagesetup (plotconfig) and you are rolling.
Make sense?
