Author Topic: Acad Install ini  (Read 6753 times)
Acad Install ini
« on: August 22, 2004, 05:24:33 PM »
Why doesn't this line work in my acadinst.ini file?
[<PROFILE>General]
PrinterConfigDir=S:\AutoCAD 2002\Plotters\
PrinterStyleSheetDir=S:\AutoCAD 2002\Plot Styles
I've tried...
[<PROFILE>General]
PrinterConfigDir=<string>S:\AutoCAD 2002\Plotters\
PrinterStyleSheetDir=<string>S:\AutoCAD 2002\Plot Styles
[<PROFILE>General]
PrinterConfigDir="S:\AutoCAD 2002\Plotters\"
PrinterStyleSheetDir="S:\AutoCAD 2002\Plot Styles"
[<PROFILE>General]
PrinterConfigDir=<string>"S:\AutoCAD 2002\Plotters\"
PrinterStyleSheetDir=<string>"S:\AutoCAD 2002\Plot Styles"
but none work??
hendie
Acad Install ini
« Reply #1 on: August 23, 2004, 03:36:47 AM »
your second version there looks as though it should work. Are you setting anything else through the Profiles section ? do those settings take effect ?
[<PROFILE>General]
would operate on values under HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\ [Version]\[Product]\Profiles\[Profile]\General
is everything else you are setting in the ini file taking effect ? (just trying to ascertain that the acadinst.ini is actually being run ok)
do you have a line similar to:
Filename: {app}\AcadInst.exe; Description: Configure AutoCAD; Parameters: {app}; Flags: waituntilidle
near the end if your iss file ?
Acad Install ini
« Reply #2 on: August 23, 2004, 10:39:08 AM »
Hendie,
The acadinst.exe is running fine. So is the only profile that is modified, has to be created by the .ini file? This will not change existing profiles? I was trying to use this install as a means of updating every profile.
Thanks,
Ron
hendie
Acad Install ini
« Reply #3 on: August 23, 2004, 11:02:15 AM »
Do you have anything under the [NewProfile] section ?
I seem to remember having some problem when I tried to modify the profiles and it created a new one but I couldn't set it current ~ but that was when I was just starting with the programme so it was most likely my fault.
if you do have something in the [newprofile] section, you could try commenting it out and see if that makes any difference. Alternatively, if you've downloaded the other prog I mentioned, there's a section in it where you can modify the registry ~ you could try that.
I'll have a play here and see if I can get it to work.
hendie
Acad Install ini
« Reply #4 on: August 23, 2004, 11:25:06 AM »
I've had a look and everything you've done seems okay ~ the second version should work from what I can see.
all I can suggest is woeful... are you passing it a valid path ~ I noticed there was no "program files" in there
sorry for such an insipid suggestion.... I'll keep playing
Acad Install ini
« Reply #5 on: August 23, 2004, 11:54:46 AM »
from what I read your version;
[<PROFILE>General]
should work.
Acad Install ini
« Reply #6 on: August 23, 2004, 12:06:41 PM »
Just did a test on one of mine and the following worked for the profile I selected in acadinst.
[<PROFILE>General]
PlotToFilePath=<STRING>C:\Temp
notice the uppercase STRING that may have something to do with it.
Acad Install ini
« Reply #7 on: August 23, 2004, 12:44:33 PM »
BINGO!!!!  Thanks Mark. That was driving me insane!
Ron :D
Acad Install ini
« Reply #8 on: August 23, 2004, 01:36:35 PM »
I'm now having trouble with my pulldown menu not loading everytime? When I initially install, everything works great. Then I close out of AutoCAD, reopen, and my pulldown menu is not loaded?? Any suggestions?
in ini:
[MENU]
MenuGroups=AQUA:AQUA:20:50
in mns:
***MENUGROUP=AQUA
***POP20
**AQUA
Thanks,
Ron
Acad Install ini
« Reply #9 on: August 24, 2004, 02:24:46 PM »
Whenever I open AutoCAD 2004, my menu loads and the mnc is recompiled. Then I open 2002 and the menu will not load. Should I not be sharing the same .mns file between versions of acad? How can I get around this?
Acad Install ini
« Reply #10 on: August 24, 2004, 05:16:21 PM »
No takers?
cadwerx
Acad Install ini
« Reply #11 on: August 24, 2004, 06:57:15 PM »
You should definitely not be using the same .mns file for 2004 as 2002.
Acad Install ini
« Reply #12 on: August 24, 2004, 07:10:25 PM »
So should I have different mns files for 2002, 2004, and 2005? If so, how do I successfully load them into the correct version of acad in one install package? Right now I'm just using the MENU portion of the ini file to load.
Anonymous
Acad Install ini
« Reply #13 on: August 24, 2004, 07:19:59 PM »
No just one for pre-2004 and one for 2004 and later versions.
BTW, this is precisely why the Uninstall= key was included in the [MENU] section of AcadInstall (in case you have pre-existing menus that you need to now version for AutoCAD).
cadwerx
Acad Install ini
« Reply #14 on: August 24, 2004, 07:24:03 PM »
That was me, I thought I was logged in :)
