Author Topic: Need mtext help  (Read 2680 times)
bman
Need mtext help
« on: August 21, 2004, 04:25:31 PM »
How can i modify this routine to prompt for the user text in the mtext editor in lieu of at the command line? Currently it mimmicks the dtext command entry line by line at the command prompt.
(defun c:L80 (/ txtht)
  (setq txtht (* 0.08 (getvar "dimscale")))
  (command "-style"
      "simplex"       ; name of text style
      "simplex"  ; font name
      txtht         ; height of text
      "1"           ; width factor
      "0"           ; obliquing angle
      ""            ; text backwards
      ""            ; text upside-down
  (while (> (getvar "CMDACTIVE") 0)(command "")) ; Vertical
  (prompt "\nCurrent Style set to L80 ")
(command "mtext")
Need mtext help
« Reply #1 on: August 21, 2004, 06:56:48 PM »
(defun c:l80 (/ txtht)
  (command "-style" "simplex" ; name of text style
           "1" ; width factor
           "" ; text backwards
  (while (> (getvar "CMDACTIVE") 0) (command "")) ; Vertical
  (initdia)
  (command "mtext")
Need mtext help
« Reply #2 on: August 22, 2004, 09:19:52 PM »
I see you got your answer on another board.
bman
Need mtext help
« Reply #3 on: August 23, 2004, 07:10:18 PM »
I forgot that i posted here too
thanks CAB
