Author Topic: Datum-adjust Cogo point elevations based on FG profile  (Read 3827 times)
sinc
« on: August 21, 2004, 03:12:11 PM »
Here's a simple routine that will datum-adjust existing points based on the centerline FG profile of the current alignment.  It's useful if you have existing points you want to change the elevation of, or if you don't want/need to go to the overhead of creating a cross-section template and setting points that way.
It will calc the grade for the point based on the profile, then applies two additional datum adjustments: a flat datum adjustment, and another calculated by multiplying a grade percentage you specify by the offset distance of the point from the alignment.  (Set these to 0 for no adjustment.)
It could use some improvements, for example: a dialogue box that pops up and asks you to select a FG profile (currently it always uses the centerline one, although you can change this in the code easily enough).
; pt2align.lsp v1.00
; Datum-adjust selected cogo points to the current FG profile.
; Can also apply another flat datum adjustment to profile grade,
; as well as an additional datum adjustment calculated from a grade
; percentage multiplied by the point's offset distance from the alignment.
; Richard Sincovec  AUG-21-2004
(if (null vll-kCurve)
  (vlax-import-type-library
    :tlb-filename "landauto.tlb"
    :methods-prefix "vll-"
    :properties-prefix "vll-"
    :constants-prefix "vll-"
   ) ;_ vlax-import-type-library
) ;_ if
(defun c:pt2align (/      acadObj aeccApp    aeccProj
  cogoPoints alignments curAlign   ss
  pt      pt_num curAlignName
  err      fgProfiles sta    ofs
  dir      elev
  (if (null *ZYZ_DATUMADJ*)
    (setq *ZYZ_DATUMADJ* 0.0)
  ) ;_ if
  ((getreal
     (strcat
"\nDatum adjustment to apply <"
(rtos *ZYZ_DATUMADJ*)
     ) ;_ strcat
   ) ;_ getdist
  (*ZYZ_DATUMADJ*)
) ;_ cond
  ) ;_ setq
  (if (null *ZYZ_GRADEADJ*)
    (setq *ZYZ_GRADEADJ* 0.0)
  ) ;_ if
  ((getreal
     (strcat
"\nGrade adjustment to apply <"
(rtos *ZYZ_GRADEADJ*)
     ) ;_ strcat
   ) ;_ getdist
  (*ZYZ_GRADEADJ*)
) ;_ cond
  ) ;_ setq
 ; should probably add more elaborate error detection...
  (setq
    err (vl-catch-all-apply
 (function
   (lambda ()
     (setq acadObj (vlax-get-acad-object)
   aeccApp (vla-getInterfaceObject
  acadObj
  "Aecc.Application"
) ;_ vla-getInterfaceObject
   aeccProj (vll-get-activeProject aeccApp)
   cogoPoints (vll-get-cogoPoints aeccProj)
   alignments (vll-get-alignments aeccProj)
   curAlignName (vll-get-currentAlignment alignments)
   curAlign (vll-item alignments curAlignName)
   fgProfiles (vll-get-fgProfiles curAlign)
   profile (vll-profileByType fgProfiles vll-kFgCenter)
   ss (ssget '((0 . "AECC_POINT")))
     ) ;_ setq
     (if ss
 (setq count (sslength ss)
index -1
 ) ;_ setq
 (vll-put-autoSave cogoPoints T)
 ;; make sure autoSave is on
 (while (< (setq index (1+ index)) count)
   (setq pt_num (cdr
  (assoc 90 (entget (ssname ss index)))
) ;_ cdr
 pt (vll-pointByNumber cogoPoints pt_num)
   ) ;_ setq
   (setq err2 (vl-catch-all-apply
(function
  (lambda ()
    (vll-stationOffset
      curAlign
      (vll-get-easting pt)
      (vll-get-northing pt)
      'sta
      'ofs
      'dir
    ) ;_ vll-stationOffset
  ) ;_ lambda
) ;_ function
      ) ;_ vl-catch-all-apply
   ) ;_ setq
   (if err2
     (princ (strcat "\nPoint "
    (itoa pt_num)
    " is not adjacent to alignment."
    ) ;_ strcat
     ) ;_ princ
(setq elev (vll-elevationAt
    profile
    sta
  ) ;_ vll-elevationAt
     elev (+ elev *ZYZ_DATUMADJ*)
     elev (+ elev (* (/ *ZYZ_GRADEADJ* 100) (abs ofs)))
) ;_ setq
(vll-put-elevation
 pt
 elev
) ;_ vll-put-elevation
(vlax-release-object pt)
     ) ;_ progn
   ) ;_ if
 ) ;_ while
) ;_ progn
     ) ;_ if
   ) ;_ lambda
 ) ;_ function
  ) ;_ setq
  (if (vl-catch-all-error-p err)
    (princ (strcat "\nError: "
  (vl-catch-all-error-message err)
  "\nMake sure current alignment is selected, and alignment has a center FG profile."
  ) ;_ strcat
    ) ;_ princ
  ) ;_ if
  (if profile (vlax-release-object profile))
  (if fgProfiles (vlax-release-object fgProfiles))
  (if curAlign (vlax-release-object curAlign))
  (if alignments (vlax-release-object alignments))
  (if cogoPoints (vlax-release-object cogoPoints))
  (if aeccProj (vlax-release-object aeccProj))
  (if aeccApp (vlax-release-object aeccApp))
) ;_ defun
sinc
« Reply #1 on: August 22, 2004, 08:54:56 PM »
Actually, I found some free time I didn't expect this weekend, and made some improvements.  It now uses a dialog box, and contains better error-checking.
; pt2align.lsp v1.01
;   - uses p2align.dcl
; Richard Sincovec  AUG-22-2004
; Datum-adjust selected cogo points to a FG profile in the current alignment.
) ;_ if
(defun c:pt2align (/ acadObj aeccApp     aeccProj cogoPoints
    alignments curAlign    ss pt
    pt_num curAlignName err
    err2 fgProfiles  sta ofs
    dir elev     count index
    profile searchArray profileTypes
    profileCodes     dcl_id
   ) ;_ /
 ;_ /
  ) ;_ if
  ) ;_ if
  (setq
    profileCodes
(list
  (cons vll-kFgCenter "Center")
  (cons vll-kFgDitchLeft "Ditch Left")
  (cons vll-kFgDitchRight "Ditch Right")
  (cons vll-kFgLeft1 "L1")
  (cons vll-kFgLeft2 "L2")
  (cons vll-kFgLeft3 "L3")
  (cons vll-kFgLeft4 "L4")
  (cons vll-kFgLeft5 "L5")
  (cons vll-kFgLeft6 "L6")
  (cons vll-kFgLeft7 "L7")
  (cons vll-kFgLeft8 "L8")
  (cons vll-kFgRight1 "R1")
  (cons vll-kFgRight2 "R2")
  (cons vll-kFgRight3 "R3")
  (cons vll-kFgRight4 "R4")
  (cons vll-kFgRight5 "R5")
  (cons vll-kFgRight6 "R6")
  (cons vll-kFgRight7 "R7")
  (cons vll-kFgRight8 "R8")
  (cons vll-kFgNone "None")
) ;_ list
    profileTypes (mapcar '(lambda (x)
   (list (cdr x) (car x))
 ) ;_ lambda
profileCodes
) ;_ mapcar
  ) ;_ setq
  (setq
    err
     (vl-catch-all-apply
       (function
(lambda ()
acadObj
"Aecc.Application"
index      -1
searchArray  nil
profile      nil
(function
 (lambda ()
   (setq
   ) ;_ setq
 ) ;_ lambda
) ;_ function
  ) ;_ setq
  (if (vl-catch-all-error-p err2)
    (princ "Could not get current alignment - make sure it is selected.")
    (if (> (setq fgProfiles (vll-get-fgProfiles curAlign)
 count     (vll-get-count fgProfiles)
   ) ;_ setq
   0
) ;_ >
  (setq searchArray
 (append searchArray
 (list
   (vll-get-type
     (vll-item fgProfiles index)
   ) ;_ vll-get-type
 ) ;_ list
 ) ;_ append
  ) ;_ setq
) ;_ while
(setq searchArray (mapcar '(lambda (x)
     (cdr (assoc x profileCodes))
   ) ;_ lambda
  searchArray
  ) ;_ mapcar
      dcl_id   (load_dialog "pt2align.dcl")
      index       0 ; initially select first profile
) ;_ setq
(if (new_dialog "PT2ALIGN" dcl_id)
    (set_tile "DATUMADJ" (rtos *ZYZ_DATUMADJ* 2))
    (set_tile "GRADEADJ" (rtos *ZYZ_GRADEADJ* 2 2))
    (start_list "FGPROFILES")
    (mapcar 'add_list searchArray)
    (end_list)
    (set_tile "FGPROFILES" (car searchArray))
    (action_tile
      "FGPROFILES"
      "(setq index (p2a:selectProfile))"
    ) ;_ action_tile
    (action_tile
      "accept"
      (strcat
"(progn (setq *ZYZ_DATUMADJ* (atof (get_tile \"DATUMADJ\")))"
"(setq *ZYZ_GRADEADJ* (atof (get_tile \"GRADEADJ\")))"
"(done_dialog 1))"
      ) ;_ strcat
    ) ;_ action_tile
    (if (= (start_dialog) 1)
(index
 (setq
     fgProfiles
     (last (assoc
     (nth index searchArray)
     profileTypes
   ) ;_ assoc
     ) ;_ last
   ) ;_ vll-profileByType
 ) ;_ setq
((princ "\nNo profile selected!"))
      ) ;_ cond
      (princ "\nCancel...")
    ) ;_ if
  ) ;_ progn
) ;_ if
(unload_dialog dcl_id)
  (and profile (setq ss (ssget '((0 . "AECC_POINT")))))
   index -1
     ) ;_ setq
(setq pt_num (cdr
    ) ;_ cdr
) ;_ setq
    (function
      (lambda ()
(vll-stationOffset
  curAlign
  'sta
  'ofs
  'dir
      ) ;_ lambda
    ) ;_ function
) ;_ setq
(itoa pt_num)
) ;_ strcat
 ) ;_ princ
profile
sta
 elev (+ elev
      ) ;_ +
   ) ;_ setq
   (vll-put-elevation
     pt
     elev
 ) ;_ progn
) ;_ if
     ) ;_ while
   ) ;_ progn
) ;_ if got ss
      ) ;_ progn
      (princ "No Finish Grade Profiles defined!")
    ) ;_ if (> count 0)
  ) ;_ if
) ;_ lambda
       ) ;_ function
  ) ;_ setq
  ) ;_ strcat
    ) ;_ princ
  ) ;_ if
) ;_ defun
(defun p2a:selectProfile (/ idx)
  (setq idx (get_tile "FGPROFILES"))
  (if (= $REASON 4) (done_dialog 1))
    ((= idx "") nil)
    ((atoi idx))
) ; _defun p2a:selectProfile
And the dcl:
pt2align.dcl - DCL definition file for pt2align.lsp
PT2ALIGN : dialog {
  label = "Datum-Adjust Points from FG Profile";
  : list_box {label="FG Profiles"; key="FGPROFILES"; is_default=true;}
  : row {
    : spacer {width=1;}
    : text_part {label="Datum Adj:"; width=12;}
    : edit_box {key="DATUMADJ"; width=12;}
    : spacer {width=1;}
  : row {
    : spacer {width=1;}
    : text_part {label="Grade %:"; width=12;}
    : edit_box {key="GRADEADJ"; width=12;}
    : spacer {width=1;}
  ok_cancel;
