Thanks for the input both of you..
Ok, with either of these, checking if the block exists, how can i therefore check the attribute values. Now i know that i can only check them if a blockreference has been inserted, so i know i can check now that a block exists in the block collections, but what i need to check is if one has been inserted, but without cycling through all the layouts, i want it to be almost instant so when the userform loads, it checks for inserted blocks and displays the attribute values on the form..
I can do the attribute check and populate the form, its just checking for an inserted block without checking every layout that i don't know..
