i found this lisp in www
but that didn;t import word table object , isn's that impossible ?
;;;Open a word document
(defun Open-Word (xfile dmode / appsession)
(princ "\nOuverture du document Word...")
( (setq fn (findfile xfile))
((setq appsession (vlax-get-or-create-object
"Word.Application"))
(vlax-invoke-method
(vlax-get-property appsession 'Documents)
'Open fn
(if (= (strcase dmode) "SHOW")
(vla-put-visible appsession 1)
(vla-put-visible appsession 0)
( T (alert (strcat "\nCannot find the source file: " xfile)) )
;;;Close the document
(defun Word-Quit ()
( (not (vlax-object-released-p appsession))
(vlax-invoke-method appsession 'QUIT)
(vlax-release-object appsession)
;;;import in AutoCAD
(defun c:Word2Acad ( / )
(if (not (member "doslib16.arx" (arx)))
(arxload "doslib16")
(setq fichier (dos_getfiled "Choose a Word document" (getvar
"dwgprefix")
"Documents Word (*.doc)|*.doc|Rich text
format (*.rtf)|*.rtf|Fichier Ascii (*.txt)|*.txt|Tous les
fichiers(*.*)|*.*||"))
(if fichier
(if (open-word fichier "hide")
(setq Selection (vlax-get-property appsession 'selection))
(setq TheDocument (vlax-get-property Selection 'document))
(setq Sentences (vlax-get-property TheDocument 'sentences))
(setq string nil)
(vlax-for for-item
Sentences
(if (= (vlax-get-property for-item 'Underline) 1)
(setq string (append string (list (strcat "{\\L"
(vlax-get-property for-item 'text)))))
(setq string (append string (list (vlax-get-property
for-item 'text))))
(setq cont 0)
(repeat (length string1)
(setq string (subst (substr (nth cont string) 1 (- (strlen
(nth cont string)) 1)) (nth cont string) string))
(if (dos_strreversefind (nth cont string) "\r")
(setq string (subst (dos_strreplace (nth cont string)
"\r" "\\P") (nth cont string) string))
(if (= (substr (nth cont string) 1 1) "{")
(setq string (subst (strcat (nth cont string) "}") (nth cont
string) string))
(setq cont (+ 1 cont))
(setq largeur (* 70 (getvar "textsize")))
(setq p1 (getpoint "\nUpper left corner of text:"))
(command "_-mtext" p1 "_w" largeur )
(setq cont 0)
(repeat (length string)
(command (nth cont string))
(command "")
(Word-Quit)
