I forgot to mention that you can pass multiple files to GS and it will create a single 'multi-sheet' PDF as well...damn good if you ask me.
Quote from: Glenn R on March 19, 2008, 05:26:28 PMI forgot to mention that you can pass multiple files to GS and it will create a single 'multi-sheet' PDF as well...damn good if you ask me.THAT would have come in handy numerous times over the years! I'm going to have to check it out for sure, now! Thanks for the very informative posts, Glenn!
pdftk G-*.pdf C-*.pdf L-*.pdf cat output all.pdf
pdftk G-*.pdf C-*.pdf L-*.pdf A0-*.pdf A1-*.pdf A2-*.pdf S0-*.pdf S1-*.pdf HVAC.pdf Electrical.pdf Plumbing.pdf "Fire Protection.pdf" cat output All.pdf
Actually, it's an EPS (Encapsulated PostScript) viewer. The PLT is just an extension really.
Code: [Select]pdftk G-*.pdf C-*.pdf L-*.pdf A0-*.pdf A1-*.pdf A2-*.pdf S0-*.pdf S1-*.pdf HVAC.pdf Electrical.pdf Plumbing.pdf "Fire Protection.pdf" cat output All.pdf*grin*
Se7en,I actually found my VBS files...they were JScript files (.js) Cheers,
