Here is a program to do what your are looking for.
Save as DimNote.lsp
;; Dimension Note - add a modifier note to an existing
;; associative dimension string.
;; Copyright 1999, Mike Lapinski
;; Permission to use, copy, modify, and distribute this software
;; for any purpose and without fee is hereby granted, provided
;; that the above copyright notice appears in all copies and
;; that both that copyright notice and the limited warranty
;; notice below appear in all supporting documentation.
;; D I S C L A I M E R O F W A R R A N T Y
;; THIS PROGRAM IS MADE AVAILABLE ON AN "AS IS" BASIS WITHOUT
;; WARRANTIES AS TO PERFORMANCE OF MERCHANTABILITY OR ANY
;; OTHER WARRANTIES WHETHER EXPRESSED OR IMPLIED. I DO NOT
;; WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;; UNINTERRUPTED OR ERROR FREE.
;; I SHALL UNDER NO CIRCUMSTANCE BE LIABLE FOR ANY DAMAGES,
;; INCLUDING BUT NOT LIMITED TO; LOSS OF PROFITS, LOSS OF TIME,
;; LOSS OF DATA OR BUSINESS INTERRUPTION RESULTING FROM THE USE
;; OF THE INABILITY TO USE THIS SOFTWARE. THE USER MUST ASSUME
;; THE ENTIRE RISK OF USING THE PROGRAM.
;; C O P Y R I G H T N O T I C E A N D T R A D E M A R K S
;; This program is copyrighted with all rights reserved by
;; Michael Lapinski. This program is for "PUBLIC DOMAIN" use
;; and may not be marketed or offered for sale to others.
;; Function: DN_ShowNote
;; Purpose: Show note selected from ListBox in EditBox
(defun DN_ShowNote (/ lnum lnote)
(set_tile "error" "")
(setq lnum (get_tile "lb_notes")
lnote (nth (atoi lnum) dm_notes)
(set_tile "eb_note" lnote)
;; Function: DN_PlaceNote
;; Purpose: If valid note is input, close dialog box
(defun DN_PlaceNote ()
(setq dn_modifier (get_tile "eb_note"))
(if (= dn_modifier " ")
(set_tile "error" "Invalid note string")
(done_dialog 1)
;; Function: DN_AppendNote
;; Purpose: Append note to selected dimension entity
(defun DN_AppendDim (val placement / ent dval)
(setq ent (car (entsel "\nSelect dimension for note: " )))
(while (/= "DIMENSION" (cdr (assoc 0 (entget ent))))
(princ "\nSelected entity is not a DIMENSION.")
(setq ent (car (entsel "\nSelect dimension for note: ")))
);while
(setq ent (entget ent)
dval (cdr (assoc 1 ent))
(if (= dval "")
(setq dval "<>")
(if (= placement 1) ;above line
(setq val (strcat dval " " val))
(if (wcmatch dval "*\\X*")
(setq val (strcat dval "\\P" val))
(setq val (strcat dval "\\X" val))
(entmod (subst (cons 1 val)(assoc 1 ent) ent))
;; Main Function - Dimension NOTE
(defun C:DNOTE (/ dcl_id dm_notes dn_above)
;enumerate this routine
(IF (= nil id:lispold)
(setq id:lispold "x")
(setq id:lispold id:lisp))
(setq id:lisp "DimNote.lsp")
(c:counter)
(setq dcl_id (load_dialog "dimnote.dcl"))
(if (not (new_dialog "dimnote" dcl_id))(exit))
(setq dm_notes '("CLR." "CLEAR" "MIN." "MAX."
"R.O." "(REF)" "TYP." "TYPICAL" "V.I.F."
"VERIFY IN FIELD"
dn_above 0
(set_tile "eb_note" "(REF)")
(set_tile "dn_below" "1") ; Set as default
(start_list "lb_notes")
(mapcar 'add_list dm_notes)
(end_list)
(set_tile "lb_notes" "7")
(action_tile "lb_notes" "(DN_ShowNote)")
(action_tile "dn_above" "(setq dn_above 1)")
(action_tile "dn_below" "(setq dn_above 0)")
(action_tile "accept" "(DN_PlaceNote)")
(action_tile "cancel" "(done_dialog 0)")
(if (eq (start_dialog) 1)
(DN_AppendDim dn_modifier dn_above)
(unload_dialog dcl_id)
(princ "\nDNOTE Loaded...")
save as DimNote.dcl
// Dimension Note - add a modifier note to an existing
// associative dimension string.
// Copyright 1999, Mike Lapinski
dimnote : dialog {
label = "Dimension Notes";
//initial_focus = eb_note;
: list_box {
label = "Notes";
mnemonic = "o";
key = "lb_notes";
height = 11;
: radio_column {
fixed_width = true;
: radio_button {
label = "Locate Below Dimension";
mnemonic = "B";
key = "dn_below";
: radio_button {
label = "Locate Next to Dimension";
mnemonic = "N";
key = "dn_above";
: edit_box {
label = "Note:";
key = "eb_note";
horizontal_alignment = left;
spacer;
ok_cancel;
errtile;
HTH, Ron
