Author Topic: Tracing a Font?  (Read 4679 times)
whdjr
Tracing a Font?
« on: February 28, 2008, 08:41:33 AM »
Does anybody know a program to trace a font so that I have an outline when I'm done?
M-dub
Re: Tracing a Font?
« Reply #1 on: February 28, 2008, 08:43:42 AM »
Depending on what the font is, you might get somewhere using the Explode Text function in Express Tools if you have it.
(I don't have acad right now to double check, but I think that might work...again, depending on which font you're using.)
Josh Nieman
Re: Tracing a Font?
« Reply #2 on: February 28, 2008, 08:52:54 AM »
Echo M-Dub.
All the fonts that are TTF, or a filled font... it leaves you with an outline... sometimes you get some triangles interspersed within the outline, but a little more exploding of the regions will leave you with lines  you can easily trim or erase away to clean it up.
Re: Tracing a Font?
« Reply #3 on: February 28, 2008, 08:58:42 AM »
What have you done with D.I.Y. Will? Exploit wmfout / wmfin ...
Hints:
• Commands: WmfOpts, WmfOut, WmfIn.
• System vars: WmfBkGnd, WmfForeGnd.
• Registry entries: ..\FixedProfile\WMF\*.*
• Insert point top left corner of viewport.
• Scale x 2.
• Examine resulting block definition, WMFn.
whdjr
Re: Tracing a Font?
« Reply #4 on: February 28, 2008, 08:59:08 AM »
You guys are the BLING! BLING!
Thanks for the help.
whdjr
Re: Tracing a Font?
« Reply #5 on: February 28, 2008, 09:01:05 AM »
D.I.Y.  ...what?
Do
It
Yourself
I have a huge deadline before I can go home tonight and I didn't have the time to spend figuring it out.
Re: Tracing a Font?
« Reply #6 on: February 28, 2008, 09:03:41 AM »
Affirmative to "Do It Yourself" and apologies. See my previous post to the swamp.
whdjr
Re: Tracing a Font?
« Reply #7 on: February 28, 2008, 09:13:31 AM »
No worries Mate!
Re: Tracing a Font?
« Reply #8 on: February 28, 2008, 09:39:20 AM »
Hints:
• Scale x 2.
Could we get some more explination please? I seem to be a little slow this morning. :-)
Re: Tracing a Font?
« Reply #9 on: February 28, 2008, 09:43:29 AM »
RDV: If you wmfout 'stuff' and then 'wmfin' same the wmf block hosts nothing but polylines, even if what you exported started as text.
Re: Tracing a Font?
« Reply #10 on: February 28, 2008, 09:50:16 AM »
That's what I thought too but, when I 'wmfout' a piece of text using a wide font then 'wmfin' the same text I get a block, so far so good, but if I explode it I get text. I am using '06 though, maybe that's why! < confused >
Re: Tracing a Font?
« Reply #11 on: February 28, 2008, 09:55:34 AM »
Ergo the mention of WmfOpts (turn off wide lines); can do the same via the registry entry, ...\FixedProfile\WMF\WideLines.
Edit: fixed horrific typo.
« Last Edit: February 28, 2008, 10:01:50 AM by MP »
Re: Tracing a Font?
« Reply #12 on: February 28, 2008, 10:27:03 AM »
I tried both options on/off in WmfOpts, still no love! What am I missing? :lol:
SDETERS
Re: Tracing a Font?
« Reply #13 on: February 28, 2008, 03:54:16 PM »
What Font you trying to turn in to text or trying to trace?
I might be able to spit out a DXF file for you quickly if it is a common Font.
« Last Edit: February 28, 2008, 03:58:23 PM by SDETERS »
Re: Tracing a Font?
« Reply #14 on: February 28, 2008, 05:08:06 PM »
Did you set wide lines off before exporting?
