Author Topic: Improving on entsel  (Read 15832 times)
Re: Improving on entsel
« Reply #45 on: February 29, 2008, 09:21:41 AM »
My last version too. :)
Took yours & gussied up the feed back, also added one.
Rearranged the exit.
;;  CAB 02.29.08, rev 02.13.2010
1) allows the user to select a single entity
2) allows the calling function to specify the prompt that will be displayed to the user
3) provides a mechanism for optional filtering of entity types, uses wcmatch filter
4) loops when missed picks
5) differentiates between a missed pick vs. the user pressing the enter key
6) will exit cleanly and return a value to the caller if the user presses the escape key
7) returns a value compatible with what would be returned by the entsel function
;;  Catch escape, allow enter, entity filter or not, wcmatch on type filter
(defun getEntity (msg ; string - select message
                  etypes ; list pf types '("LINE" "CIRCLE") or pattern "Line,*Polyline"
                  ent
  (or ; except nil or single string or list of strings, force strings to upper case
    (null eTypes)
    (and (listp eTypes) (setq eTypes (mapcar 'strcase etypes)))
    (setq eTypes (list (strcase eTypes))) ; make into a list
  (setvar "ERRNO" 0) ; reset error flag
  (if  ; this will catch ESCape & return nil
    (vl-catch-all-error-p
      (vl-catch-all-apply
        '(lambda ()
           (while ; return nil to exit
               ((and (null (setq ent (entsel msg)))  (/= 52 (getvar "ERRNO")))
                 (princ "\n*-> Missed, Try Again."))
               ((= 52 (getvar "ERRNO")) (prompt "\n*-> User Quit."))
               (etypes
                   (if (vl-some '(lambda(x)
                               (wcmatch (cdr (assoc 0 (entget (car ent)))) x)) etypes)
                       (prompt "\n*-> Selection made successfully.")
                       (princ "\n*-> Wrong entity type, Try Again.")
                (ent (prompt "\nselection made."))
           ) ; end while
     nil ; error return
     ent
« Last Edit: December 06, 2010, 08:33:01 AM by CAB »
« Reply #46 on: February 29, 2008, 10:48:21 AM »
Just for kicks; can i get a brief description of what you want/are thinking of? The reason i ask is because, you guys keep talking about feedback and using `catch-all' -- I was wondering the reason for that...instead of say, just exit on a null user return (esc and enter) -?
Chuck Gabriel
« Reply #47 on: February 29, 2008, 11:48:31 AM »
By feedback, I mean notifying the user that he either missed the pick or selected the wrong type of entity.
The reason for using vl-catch-all-apply is because this function will generally be called by other functions, and it is sometimes useful to let the caller know that the function failed, and decide what to do about it, rather than just aborting everything including the calling function.
So the specification would go something like this:
Provide a function that
4) is tolerant of missed picks
« Reply #48 on: February 29, 2008, 11:57:44 AM »
Cool thanx, i might try and get my hands dirty with this after my project goes out. Sounds like fun.
daron
« Reply #49 on: February 29, 2008, 01:37:57 PM »
You know what would be cool? At least I think it would. Add to the return value the converted object. So you would have (<Entity name: blahblahblah> (0.0 0.0 0.0) <VLA-OBJECT IAcadLine blahblahblah>)
I know, easy, but why not?
