Author Topic: Array kept centered  (Read 3741 times)
Shade
Array kept centered
« on: February 26, 2008, 11:57:11 AM »
Attached find a DB of a piece of corelsab.
I would like the hollow core slab to be stretched from one end only thereby allowing me to have any size length, with the hollow cores centered at all times.
I can't seem to figure out how to have the cores centered at all times :-(.
Help would be appreciated.  :mrgreen:
daron
Re: Array kept centered
« Reply #1 on: February 26, 2008, 01:49:01 PM »
If you want to have the single hole centered at all times, use a move action connected to the stretch action and set its distance override set to 0.5. Get rid of the distance parameter on the circle itself and the array.
Now, if you want to array, that's a little more complicated and I have posted in the past a buffet plate warmer, that does exactly what you seem to be asking. I'll look for it.
daron
« Reply #2 on: February 26, 2008, 01:51:38 PM »
Here it is. Download the drawing in that post. It should give you some sort of direction.
